maybe my ears are not well trained...but i only (barely) hear three different tones here...
the first one is obviously different
then theres the longer cable one...i didnt really hear a difference from the type of cable
then there's the buffer in the chain...i didnt really hear any difference between types of buffers or stacked buffers...
The buffer helps...but i think in these examples its not that big a difference. I wonder if he used a 5-10 pedal chain then the difference would be more amplified...?
Gotta say I'm kinda jealous of the amount of money @Jaden must be saving on loo paper.
Ok Eric, buffers 101!
In a properly engineered and organized string of audio effects devices such as you might find (less and less now!) in a recording studio, compressors, reverb units, enhancers, di-da, there is no need for a buffer because the output of the mixer/interface/tape machines was at Low Impedance and that means that said output was virtually unaffected in terms of frequency response or level by whatever was connected to it (input impedances were almost always 10,000 Ohms, often much higher) .
But electric guitars are not like that! They have a relatively high output impedance (aka Z) which is also a mad mix of inductance capacitance and just ice the cake, changes with the pickup selected and the position of the volume and tone pots!
This did not matter much when guitars plugged straight into a valve amplifier because they have a very high input Z, of 1,000,000 Ohms, the "magic meg".and since all the processing took place inside the amp, all was cool.
Then came the Fuzz Box (or whatever the first pedal was!) and unfortunately it was very tricky to get a 1 meg input Z with transistors (not impossible by any means but you needed extra devices and peeps were cheap) .
So the very early pedal *****d with the guitar's signal when on and left it at the mercy of everything else further down the line when off because they were BADLY ENGINEERED! (at least from a technicians point of view) .
Good pedals IMHO incorporate neutral buffers to isolate the guitar from further messin' from daft TB pedals and cables.
Dave.
