How do I ... How does this work ... How (etc)
  • SporkySporky Frets: 28490
    Misterg said:
    Sporky said:
    I think it'd be useful to be able to see what one had been facepalmed for. However, I think it's critical that the votes be anonymous.
    Haven't we already got that? The buttons under each post seem to show how many times they've been hit - like you got +1 wisdom for the post I quoted, and somebody (holnrew) got two facepalms for this ...
    (Or am I being dense?)
    We almost have - what you've said works, but potentially you have to trawl through all your posts to find that one facepalm.
    It would be nice, if the plugin supports it, to be able to go from your profile and see all your posts which got a "Wow" or Facepalm. Does that make sense?
    ddlooping said:
    Paulo said:
    Clicking in the comment area doesn't activate the keyboard on my Nexus 7. It seems to work when I click the two red arrows (source?)
    Probably because the WYSIWYG uses an iframe superimposed to the comment area.
    I don't think this behaviour can be modified though. :-S
    I get  a similar problem, cursor doesn't appear when I click in the comment box.  <> arrows to go to "view source" and I get flashing cursor OK, but going back still doesn't show cursor.  If I just type after clicking on comment box straight off, it works OK. (which I only just found out)
    Same thing happens sometimes if I go to another application and back again.
    *** My way around this was / is to reload the page and then everything works just fine.
    I don't have a problem with this, just included this for information, and as it maybe a subset of the same operational issue.  Don't know if any of that helps?
    Config: Apple MacBook Pro, Sys 10.6.8 (so I can run Power PC software) Safari 5.1.9.
  • gusman2xgusman2x Frets: 921
    Is there a 'Recent Discussions' option on the mobile site?
  • bertiebertie Frets: 13569
    this
  • MistergMisterg Frets: 352
    Yup!
    what about a feature that lets you 'group' users from geographic areas....... based on their 'location' choice. ??
  • thumpingrugthumpingrug Frets: 2927
    Oh  that sounds like a good idea.  Or an interactive map?
    any update on the not being able to delete all drafts  problem ?
    The X on the right just takes you to the edit, and doesn't delete it.
    @gusman2x was there an answer there that dropped off the post, or were you trying to highlight my as yet unanswered question?
    Works for me <:-P
    Sure you're not double clicking ?
    Feedback
  • ddloopingddlooping Frets: 325
    edited August 2013
      @bertie, could you let us know what browser/platform you're using?
    @not_the_dj, we will be looking into adding it. :)
    No man, was trying to highlight the question, as I've asked it a couple of times, and no answer. Without this feature, I find the mobile site pretty much useless, for how I like to browse the forum anyway.
    edited August 2013
    Chrome,  W7 64bit.  on three separate machines
    It appears to work when it feels like it.  Didnt work at all yesterday,  it worked once today and then didnt.
    EDIT
    and now it worked again.
    edited August 2013
    Thanks, @bertie, I'll investigate.
  • TTonyTTony Frets: 27630
    just to make it curiouser and curiouser (said Alice), I've used that exact same set-up with no problem.
    edited August 2013
    appears to be working OK now...................... for now.
    Here's another tho ..................  wherever you try and put a smileee in your post, (going to put it here.....>>   it always gets put at the end - and you have to cut/paste it to where you want it.
    EDIT
    see ?!?!
    edited August 2013
    I can't reproduce the "Drafts" bug in W7 64bit with Chrome I'm afraid.
    I did say - "it appears to be working now"     :)>-
    It's bound to reoccur though, as nothing was done to fix it. :/
    EDIT
    see ?!?!
    I have experienced this also. On the list!
