http://www.thefretboard.co.uk/discussion/57632/
My YouTube Channel
That's why I mentioned the Lazy J above. With the 6L6 power valves rather than 6V6 and the Celestion Blue it's can get reasonably loud as well - probably more than double the clean volume of a traditional Tweed Deluxe. If you get the reverb option it adds weight but as the OP says he never uses reverb then get it without and it's really light.
One more thought. If you don't use reverb, would the amp continue to function if you took the reverb tank out? It wouldn't be a massive weight saving but it would make it a bit lighter.
Offset "(Emp) - a little heavy on the hyperbole."
Has anyone checked these Matrix amps?
http://uk.matrixamplification.com/guitar-amps/vb800.html
1.8kg or about 4lb in old money.
Yes, but not significant - only about a pound even with the bag, I think. You can safely take the tank out of a HRD because it's solid-state-driven, but don't assume that's so with all Fenders or other valve amps with reverb - although you can always pull the reverb drive valve as well, which then makes it safe.
Custom carbon fibre/kevlar cabinet?
I bet it would sound dire mind.
But the next serious options are going to be the lower powered princeton which is more expensive but quite beautiful sounding or in my experience the rather nice Roland Cube series in the 'black face' setting.
I am not a great fan of digital and often find that after a period of time the artifices of digital guitar sound can be tiring, I found the Cubes to be less so. Very light.
I tried the older styling with the word Roland on the front like this:
http://www.ebay.co.uk/itm/Roland-CUBE-60-COSM-Amp-/321693012117?pt=LH_DefaultDomain_3&hash=item4ae665d095
Current styling has Cube on the grill.
Worth a look see.
calling @photek . A Fender flavoured version rumoured to be in the works,which would be a more obvious replacement for an HRD.
Of course there's always the 68 deluxe reverb custom combo which is cheaper new, although possibly not as many available second hand right now, and not available as a head.
I will also say that I was tremendously impressed by the 65 reissue Princeton I tried recently -awesome twang and bluesy growl in a tiny box, with fantastic reverb and trem. Some folks have reported that they go a bit harsh and ratty when cranked, I'm guessing this may have a lot to do with the speaker, but again you could replace it with something a bit fatter sounding, and some folks even manage to stick a 12 incher in there.
