So the guitar I'll next build will be wudtone finished with a swamp ash or mahogany back and a figured maple cap with maple neck and board.
It'll be blue with a mahogany or black back and sides, which is nice
![:) :)](/plugins/EmojiExtender/emoji/fb/1.gif)
but I want masked binding.
To do the edge should be straight forward enough - mask it off pre colour, do the colour and base coats on back, sides and front, remove masking and apply colourless base coat to the masked area. However, I was a very thin masked bit on the front of the guitar.
How do you do this? Do you scrape it off with a Stanley knife? I can see that going really quite wrong...
Or is there a super secret best friends' trick to getting it right?
After all of this, I'll gloss the whole lot with wudtone gloss topcoat. Which is not totally gloss, but nice and easy to work with and looks pretty great.
I'll wudtone the neck, too. Andy will get plenty of business from me
Instagram
Wez, you're right. That makes it look dead easy
For me, the whole cap will be the binding, so I've got the exact thickness on the guitar marked off for me - probably 1/4 inch or so. My main worries were bleed and how to get a super fine masked area on the top. I might not manage that, to be honest. I don't know if I want to scrape it, it sounds too risky for an amateur such as me...
I planned my built meticulously last time, and it went mostly smoothly, so that's what I'm doing now. No doubt you guys will get a couple more questions fired at you, but for now, that's me satisfied.
I'll PM you at the time I imagine, if you don't mind.
Wez, you might get questions too. I've lusted for some of your builds before...
Instagram
Cheers
Instagram
What he said, that is lovely too.
