Disaster struck
BidleyBidley Frets: 2933
So after our first set on friday, I knocked my guitar off it's stand...
http://i.imgur.com/gGp0m20.jpg
Not the cleanest break ever, eh. Do we think it's terminal?
  • bluechargeboybluechargeboy Frets: 1906
    Bad one dude. :( Did you have to cancel the rest of the gig?
  • BidleyBidley Frets: 2933
    No, thankfully we had two spares on standby, and I play mandolin most of the time! We went down a storm too so it wasn't too painful.
  • steamabacussteamabacus Frets: 1268
    Having seen what @FelineGuitars did with that Judas Priest guitar, I'd say it's eminently fixable.
    Good on yer, the show must go on. Even if you feel like screaming...
    I saw that thread first time around. Impressive work, but not really an option on a guitar worth about £200!
  • ThorpyFXThorpyFX Frets: 6217
    ouch!!
    Adrian Thorpe MBE | Owner of ThorpyFx Ltd | Email: thorpy@thorpyfx.com | Twitter: @ThorpyFx | Facebook: ThorpyFx Ltd | Website: www.thorpyfx.com
    Got to be worth a punt with some glue, right?
    Difficult to say. It can be pushed back together pretty snugly. It'll never be an invisible repair but long term could I rely on it? I wouldn't want to gig it again only to have the headstock ping off!
    @ICBM, what say you?
  • TTonyTTony Frets: 27658
    @WezV is one of our more experienced guitar fixer-ers.
    Great shout, cheers @TTony
  • FelineGuitarsFelineGuitars Frets: 11624
    That will mend ok - get a simple mend for strength and ignore the cosmetics (as the cosmetic bit of the repair tends to be more expensive than the physical repair.)
    Thanks for that @FelineGuitars, very reassuring! Just as well I'm not fussed about looks :)
    You can always go back and have the looks redone later , but I would do the woodworking fix and see if it holds out.
    The join itself will e strong - the only issues can be that the wood fibres 1-2mm away from the break may have been weakened and if you were to knock it or drop it , then that is where a break would reappear if at all.
    edited July 2015
    Definitely. That's the worry, it didn't cleanly break off, it fell face first, cracked, then the string tension pulled the remainder off.
