I've got a large circ saw/plunge saw (no rail) that's good for large pieces. Also got an Evolution sliding chop saw, like a plunge with a base. The circ has to be over a free edge to allow for the blade but the chop base takes care of that.
I got the Evo mainly for metal but the blade is multi-purpose and eats wood very easily & neatly.
Dunno if that helps any. They both do a job, for slicing large sheets the circ saw is the thing, for guitar-sized things the chop saw is mostly better. Much more control and a finer cut, light & movable too.
Wouldn't necessarily recommend the Evo, the blades are pricey, a dedicated wood one should be cheaper on that front. I'd go sliding not fixed, whichever way.
@equalsql what sort of jobs have you got in mind?
Circ saw for ripping sheet, worktop etc, mine was only £30ish at the time so not pricey but no good for guitars.
Bandsaw for getting close to a guitar outline.
Done loads with the chopsaw, car rebuilds, workbenches, fences, firewood etc.
Horses for courses. I wouldn't be without any of them, luckily the bandsaw was a broken freebie, but each has paid it's keep many times over.
I know that they are more of a one-trick pony, but obviously take up a lot less space, hence my query on here for anyone who actually uses one
http://www.axminster.co.uk/progrip-guide-clamp
Handy things for sawing and routing, though you do need to make sure you keep it up to the fence and dont let is drift. I use one on my router table as a mount for these when making beading and such.
http://www.axminster.co.uk/progrip-featherboard
