Can you get a decent final finish using spray cans?
All of my guitar projects have an aged look because I prefer them that way, but also it seems a lot easier to do. I'm just starting something at the moment that I'd like to have a shiny new look. Is it possible to get a decent finish just using cans of lacquer, or do you need a spray gun of some sort? would it take many cans to achieve?
  • paulnb57paulnb57 Frets: 3057
    edited September 2015
    Yes! It is possible
     No! You don't need a spray gun
     Dunno! How much you would need....
    It's all about quality of the can contents and your skill in applying them......some areosol (cheap) have more percentage thinners to paint ratio so don't cover well.....
    Ive sprayed guitar bodies with Halfods Satin black woth good results also with car paints mixed by car paint supplier, I will not buy cheap shit paint!
    No experience with lacquer, but would expect the same to apply....
  • WezVWezV Frets: 16746
    Its  also a lot to do with prep work
    with really good prep you can do one can of primer or sanding sealer, one can of colour and one can of clear on a body.... but more usually its 2 cans of primer/sanding sealer, one colour, 2 clear - allowing enough for fudge room and levelling off.   it adds up quickly
    this is the one i just did
    i brought some normal sanding sealer and brushed on a few coats first - making sure i could sand back to a level surface before spraying the burst and top coats
    the reflections and white spot on the edge tell you its not perfect
    Shellac?
    usedtobe;766529" said:
    Shellac?
    Never sure really. I like a good French polish, and shellac makes a great sealer that plays well with other finishes.
    But do you want a finish that will be so easily ruined by water or alcohol?
    Just a query, tbh. I'm completely in the dark as regards sanding sealer. I googled 'sanding sealer', and a shellac based one, I could buy locally, came up. What would you recommended?
    Edit. Suppose it depends on finish? Is there such a thing as a good all-rounder?
  • Northwest Guitars or Rothko & Frost for Nitrocellulose in rattle-cans and related finishing products...
    ...and lots of patience!
    If I am going for an aged 'road worn' finish I'll empty a can of primer in one go, spraying the coats on as fast as they'll go without running; leave to harden for a good few days then flat back lightly. Repeat process with gloss top coat and voila, instant 40-years-worth of character!
    However, a nice shiny finish takes bl**dy forever!
    Half a dozen very light coats, leave to harden, flat back, repeat ad infinitum, taking care not to rush a single stage; ultimately very rewarding though... ;;)
    Google ReRanch for probably all the guidance you'll ever need.
  • SteveRobinsonSteveRobinson Frets: 7063
    You certainly can. Check my blog for examples of the results that I and my customers have achieved.
    In my blog you'll find demos and videos showing techniques etc. and I'm always happy to give advice to customers.
    As @WezV says, preparation is everything, all else follows.
    Guitars sprayed using my aerosol lacquer are in the window of a certain top-end guitar shop, so if it's good enough for them?
    Throwing a can of primer and a can of colour on your guitar will not produce an authentic looking aged finish, but it depends what you are aiming for I suppose.
    @usedtobe I wouldn't recommend a shellac based sealer as they often contain a lot of stearate which can cause adhesion problems with nitrocellulose. Best use a cellulose-based one.
  • DiscoStuDiscoStu Frets: 5546
    Warm cans, and lots of very light coats with light sanding in between. Leave to cure for a month before doing the final sand and polish. Done.
  • SteveRobinson;767034" said:
    You certainly can. Check my blog for examples of the results that I and my customers have achieved.http://www.manchesterguitartech.co.uk/category/finish/
    You do realise that, thanks to you, I'm looking at doing yet another project and searching for an affordable pine body from guitarbuild so I can try nitro for the first time?
    Bad guitar tech. Bad boy.
    Thinking of trying a two tone sunburst strat... To complement my other strat in wudtone fiesta red.
    This one turned out nicely (done by a regular customer)
    @DiscoStu I think that sanding between colour coats is a waste of lacquer. I never sand unless a speck of dust gets in the finish.
    If you let the base coats of sanding sealer and/or primer harden and sand them flat, all the other coats should go on smoothly meaning that you only need to do minimal flat sanding of a bit of orange peel at the end, if any. Quite often I'll just buff the finish out of the can, e.g. http://www.manchesterguitartech.co.uk/2012/12/16/new-build-mary-kaye-stratocaster/ (owned by @Basher) and http://www.manchesterguitartech.co.uk/2011/09/10/ice-blue-metallic-telecaster-assembled/
    @SteveRobinson I should have been more specific. I had a few bits of dust to deal with given that I don't have a spray booth.
    Ah yes you did say a light sand sorry :)
  • axisusaxisus Frets: 28341
    Many thanks @SteveRobinson - I will be using your cans of course!
    Thanks - I'm sure I can sort a discount out for a forum member. :)
  • BasherBasher Frets: 1206
     Quite often I'll just buff the finish out of the can, e.g. http://www.manchesterguitartech.co.uk/2012/12/16/new-build-mary-kaye-stratocaster/ (owned by @Basher) ;
    And a killer Strat it is too!
    Sounds and feels fantastic. Currently saving the pennies for a medium-jumbo refret and then I've got "my" strat for life.
    I genuinely feel that Steve was on to something with these deliberately thin/fragile finishes. Mine looks like a custom shop relic, albeit with the dings and scrapes inflicted by me, after a couple of years' relatively light use.
  • Agree with you @Basher. @SteveRobinson built my Telecaster for me and I specified a very thin satin finish which has aged beautifully. It's lovely work and the guitar is naturally reliced.
  • gfsgfs Frets: 10
    As @SteveRobinson & @WezV say prepping is everything never take short cuts.
    if this is not done right all your mistakes are gonna show up,
    I recently finished this les paul project using nitro spray ( heritage cherry and amber laquer ) from kevin @ northwestguitars, the finish has come out lovely. i find i do get better results using a proper spray gun rather than using the cans. but thats just me.
    Here's a Les Paul finished in my aniline cherry lacquer and faded.
    Here is how the colour builds with successive coats (bottom right to top left)
  • gfsgfs Frets: 10
    @SteveRobinson your making me want to start a new project damn you. That top has a lovely finish.
  • rexterrexter Frets: 369
    Some very good advice above, preparation and patience really pay off. From my own personal perspective it's very easy to want to rush the job to see the finished product but this always leads to frustration and a bad paint job... take it slow and don't ever be tempted to spray a little more just because your last coat has gone on so nicely. Exuberance always leads to runs!
    I am about to start spraying another Jazzmaster body and have spent ages sanding it to perfection up to 400 grit (maybe a bit extreme). Best results I have had so far are on a body that was sealed and primed a good three months before i sprayed the colour coats.
    Custom colours, vintage restorations, high end guitar finishing
    www.rexterguitars.co.uk
