FS Fryette PittBull 100CL Heads. NOS Brand New & Demo (SOLD)
We have 2 remaining Brand New Fryette PittBull 100/CL Heads, Ltd Production Non EQ Models. Back from when we used to deal with Fryette AmplificationAwesome sounding and very versatile 2ch High Gain Amps.
1, Brand New Open Box and Customer Demo Model (has been stored in the box, not on display) £999.00
2, Brand New Factory Sealed and never opened £1199.00
Both with FREE UK Postage
Specs:
Pittbull Hundred/CL Designed for straight ahead players who prefer to rely on the guitar volume for the clean sound, the Hundred/CL will fly you through spanking clean, classic rhythm crunch and full on solo territory in about a half a heartbeat. Two channels of unapologetic attitude with a 100-watt power plant, deliver thick touch sensitive response with a decidedly British persuasion. The Pittbull Hundred/CL is a no-nonsense amplifier with a deceptively simple feature set in which either channel can serve as a Clean, Crunch or Burn channel. The CL’s Red & Green channels are similarly configured but voiced slightly differently for a wide palate of pristine clean, slightly dirty clean, spanking crunch and aggressive but harmonically rich overdrive. Combined with an extremely expressive graphic EQ, this allows for quick and intuitive sound sculpting. Experience pure simplicity and total control with excellent note articulation and chordal clarity.
Front Panel
Input HI/LO
Channel Switch
Red Channel:
Red Gain, Hi Gain Switch, Red Volume, Boost, Treble, Edge, Middle, Shift, Bass
Green Channel:
Green Gain, Hi Gain Switch, Green Volume, Boost, Treble, Edge, Middle, Shift, Bass
Master Volume
Standby (Standby/Half Power switch on Hundred/CL)
Power
Presence
Depth
Voicing Rear Panel
Ground Switch
AC Input
Mains Fuse
DC Fuse
Power Amp Mute (Hundred/CL)
Dual-Class™ Mode (Hundred/CL)
Enhance Mode (Fifty/CL)
Class A/AB Mode (Fifty/CL)
Impedance Selector
Speaker Output Jacks
Line Out Level
Line out
Footswitch Jack
Loop Switch
Loop Return Jack
Series Parallel Switch
Loop Level Switch
Loop Send Jack
Loop Level/Mix .
Features
Two channels: RED & GREEN
Gain Stacking™
Series/Parallel Effects Loop
Variable Line Out
Presence
Depth
Voicing
Hundred/CL
Power Amp Mute
Half Power Mode
Dual-Class™ Mode
Power output
100 Watts RMS (Hundred/CL) Impedance
Selectable for 4, 8 or 16 ohms
Tube Complement
Hundred/CL
1-12AX7WB (Russia)
3-12AX7AC (China Selected)
4-Premium Matched EL34 Power Tubes
