FS Fryette PittBull 100CL Heads. NOS Brand New & Demo (SOLD)
StormshadowGuitarsStormshadowGuitars Frets: 1218
edited November 2015 in Amps £ tFB Trader
We have 2 remaining Brand New Fryette PittBull 100/CL Heads, Ltd Production Non EQ Models. Back from when we used to deal with Fryette Amplification
Awesome sounding and very versatile 2ch High Gain Amps.
1, Brand New Open Box and Customer Demo Model (has been stored in the box, not on display) £999.00
2, Brand New Factory Sealed and never opened £1199.00
Both with FREE UK Postage
  • StormshadowGuitarsStormshadowGuitars Frets: 1218
    Specs:
    Pittbull Hundred/CL Designed for straight ahead players who prefer to rely on the guitar volume for the clean sound, the Hundred/CL will fly you through spanking clean, classic rhythm crunch and full on solo territory in about a half a heartbeat. Two channels of unapologetic attitude with a 100-watt power plant, deliver thick touch sensitive response with a decidedly British persuasion. The Pittbull Hundred/CL is a no-nonsense amplifier with a deceptively simple feature set in which either channel can serve as a Clean, Crunch or Burn channel. The CL’s Red & Green channels are similarly configured but voiced slightly differently for a wide palate of pristine clean, slightly dirty clean, spanking crunch and aggressive but harmonically rich overdrive. Combined with an extremely expressive graphic EQ, this allows for quick and intuitive sound sculpting. Experience pure simplicity and total control with excellent note articulation and chordal clarity.
    Front Panel
    Input HI/LO
    Channel Switch
    Red Channel:
    Red Gain, Hi Gain Switch, Red Volume, Boost, Treble, Edge, Middle, Shift, Bass
    Green Channel:
    Green Gain, Hi Gain Switch, Green Volume, Boost, Treble, Edge, Middle, Shift, Bass
    Master Volume
    Standby (Standby/Half Power switch on Hundred/CL)
    Power
    Presence
    Depth
    Voicing Rear Panel
    Ground Switch
    AC Input
    Mains Fuse
    DC Fuse
    Power Amp Mute (Hundred/CL)
    Dual-Class™ Mode (Hundred/CL)
    Enhance Mode (Fifty/CL)
    Class A/AB Mode (Fifty/CL)
    Impedance Selector
    Speaker Output Jacks
    Line Out Level
    Line out
    Footswitch Jack
    Loop Switch
    Loop Return Jack
    Series Parallel Switch
    Loop Level Switch
    Loop Send Jack
    Loop Level/Mix .
    Features
    Two channels: RED & GREEN
    Gain Stacking™
    Series/Parallel Effects Loop
    Variable Line Out
    Presence
    Depth
    Voicing
    Hundred/CL
    Power Amp Mute
    Half Power Mode
    Dual-Class™ Mode
    Power output
    100 Watts RMS (Hundred/CL) Impedance
    Selectable for 4, 8 or 16 ohms
    Tube Complement
    Hundred/CL
    1-12AX7WB (Russia)
    3-12AX7AC (China Selected)
    4-Premium Matched EL34 Power Tubes
  • DeijavooDeijavoo Frets: 3299
    I've only heard an EQ model, which I assume is almost identical and it sounded ridiculously aggressive. Great amp.
    There's a little more scope on the EQ model, minus the Voicing switching. But the same amp essentially the same amps, from crystal clean to tight saturated bowel emptying distortions on both channels.
  • Buy with confidence .. Richie is a top bloke
  • 1 of my favourite amps of all time and sounds amazing.. just can't justify another amp head with having the Rivera and Stoneham.
    I'm in two minds whether to keep one as they do sound awesome, but it'd probably not get used with all the others laying around here these days :)
    Bump
    Bump
    Easily in the top 5 high gain amps I've ever played through, incredible heavy rock tones.
    Yes, they're awesome amps, great tones and very versatile. Often underrated and overlooked.
    We have 2 left NOS available :)
    Weekend High Gain Bump
    Both Sold
