Hondo II project
13»
  • SkodadadSkodadad Frets: 509
    Better picture closer to actual colour. Really pops in good light though.
    Quick update, added a roller bridge for the tremolo, had to fill the bridge holes with dowel and redrill as the posts were pretty small. Had noticed the tunomatic was moving backwards and forwards with the tremolo though tuning was only a tiny bit out afterwards. No movement now with rollers and looks quite smart too. Might try and find a les Paul roller nut too, all I can see so far is Tele a Strat versions. Have all new chrome screws on the way, excuse the b&q ones. image
  • robwrightrobwright Frets: 738
    Love that!
    Top job mate
    Cheers @robwright it still needs some work on the neck but it's playing. I may have to get another neck at some point as I can't get the action low enough for my liking without buzzing frets near the neck joint. Have tried adding relief but it makes th action too high.
  • SargeSarge Frets: 2429
    Time to invest in some fretting tools!
    It's reasonably easy to taper away the last few frets to stop the buzzing /choking.
    Can you recommend a reasonable starter kit? Cheers
    starter kit? not really, but I can point you to all the tools I started off with, though not till Monday evening.
    Cheers @sarge I'm sick of buying the wrong things
    m.ebay.co.uk/itm/Professional-Fret-File-Large-Jumbo-Fretfile-Crowning-File-/301771847691?nav=SEARCH
    m.ebay.co.uk/itm/TECHNOFRET-Advanced-Fret-Leveling-System-/180677890090?nav=SEARCH
    so these are the bare minimum I would use, a fret levelling beam and crowning file.
    m.ebay.co.uk/itm/Micro-Mesh-MicroMesh-Cushioned-Abrasive-Polishing-Kit-9-Sheets-of-6-x4-/331508474204?nav=SEARCH
    micromesh cloths for polishing after crowning.
    m.ebay.co.uk/itm/New-Crimson-Guitars-5-edged-Fret-Rocker-/161120059710?nav=SEARCH
    and the fret rocker for finding which frets are high or low, these can be had for about £5 but those tend to put tiny nicks in the frets.
    apologies if these links don't work, I'm using a tablet at the moment and it's not keen on playing ball!
    I should point out I linked a jumbo fret file, you may well feel the need for a medium or narrow, in my experience the jumbo has covered all but one guitar for me so far (20+)
    Cheers @sarge I'll get ordering
    Research them first, they suited me but there are other viable options!!
    OK more reading :)
