i play in a couple of bands one of which is function based. Used to have the fender supersonic. now use a h&K statesman El34 head, with a zilla cab (closed). Works brilliantly for both bands, and I think the H&K is a vast improvement on the supersonic personally.
Sounds good. A lot to be said for vertical stacking like that, and option of extra cab or not, depending on venue. Fits in a small car too.
If you're struggling with low end, try a bad monkey* with the bass set high, treble to taste and gain set low. Works really well for me anyway.
I'll get back on the Marshall GV-2 when I've had a proper try with it.
