The CR60C appears to be a decent-quality, well-designed, and well-engineered piece of kit. It is totally analogue and really only does one sound - but it does it extremely well indeed. You wouldn't mistake it for a valve amp but it really is pretty close. If you want modelling, or to be able to plug your MP3 player into an aux input, then look elsewhere. If you want a gigworthy solid state amp then this is pretty good.
I have only tried the CR35RT in a shop, and TBH I have to say I wasn't overly impressed. To be fair I only had a ten-minute go, but I'd say it wasn't in the same league as the CR60C - in fact, not even close. However, for a bedroom amp, it's perfectly good and would probably be loud enough for small gigs. As I recall, it did have aux in and headphone out sockets.
http://www.thefretboard.co.uk/discussion/57632/
