Right, to make the pedalboard I'm building that little bit more useable I could do with a tuner with the input and output jacks (and ideally the power jack, if there is one - not essential) on the top. The ideal candidate will also be of a small footprint and run off a 9V battery AND standard power supply, and MUST track bass well down to a low B.
I've seen the Korg DT10 (would do the job, on the large side though), Pitchblack + (ditto) and the Guyatone MT3 (I think - small, but seemingly a bit rare and pricey when they do come up). What am I missing?
Nil Satis Nisi Optimum
You may have to Google it.
http://i1001.photobucket.com/albums/af135/roscoe2911/tu_1000_top_gal_zps5a73ce07.jpg
Bandcamp
Spotify, Apple et al
It does indeed; that's what I'm using at the minute it's just a SMIDGE too big to allow everything to fit on a PT Mini though, and I need to save stage space (in a five-piece with a Hammond and sax occasionally playing pubs, my board needs to be as small as I can get it ) - going to relegate the DT10 to acoustic gig duties and see if I can down-size!
oh, just googling the tuner. Might be an old page or something, didn't check the date. Yep, doesn't seem to be on the GG site, my bad. Anyway, it has top edge mounted jacks... X_X
Tiny little thing. Won't notice it is there.
