http://www.theboxwoodchessmen.com/
https://www.facebook.com/tingiants/?view_public_for=231700547508938
However if the gig was that important I would negotiate using my favoured setup which is a Bad cat or matchless amp on the edge of breakup and a klon.
I like using my stuff for gigs the way I like it setup.
That's exactly what I use mine for... although not at big gigs because I don't play those! Just small ones. As ThePrettyDamned said it's an extremely versatile, great-sounding overdrive/distortion pedal. I also think it does clean up pretty well, I've sometimes left it on the whole time and just used the guitar volume. It also has a useful pseudo-feedback function for if you're playing at too low volume to get real feedback...
Best pedal ever.
I almost thought I'd typed MT-2 by mistake .
It does clean up at lower gain settings but nowhere near as well as, for example, a fuzz face (which goes crystal clean from utter filth). At higher gain it tends not to do well and stays a bit grainy, although it can be good for going from overdrive to distortion.
I use mine with the gain at 1/4 or so with a strat and a hair higher for humbuckers. Sounds great. It is the best sounding general overdrive ever.
Rats are very good too, mind, and probably more versatile with the fuzzy sounds.
ear says either - its all the same to the crowd.
PA Hire and Event Management
Also the true bypass is a problem when going into some 'non guitar' amps, or you need to use the FX return which is sometimes a lower impedance and will then muddy the clean sound if you turn the pedal off. Boss (or something else buffered like a TS-9) wins for that.
Bar a Fuzz, It's the only dirt pedal on my traditional board.
My own choice at the mo is the Amptweaker Tight Drive Pro.
Apart from sounding great, it's send and return facilities are a brilliant idea.
