51 P Bass Semi-acoustic: The Bass Fender Forgot to Make
    It’s had a good dry out and harden, and so I’ve given it a going over with the 1200 grit wet and dry with water this time. Silky smooth. Really pleased with the finish - it’s actually better than I thought Danish Oil would be - and I highly recommend it for an easy to do finish that looks great.
    I will let it harden properly overnight and give it another smoothing off.
    So far:
    Had a quick trial fit of the electrics and the knobs just to make sure they looked okay ;)
    Yeah - they look ok...
  • John_PJohn_P Frets: 2750
    That’s going to look awesome when it’s finished.    Tempted to have a go at one myself but I’d have use a reverse headstock.
    I’m impressed with the oil finish - did you need to use grain filler or just straight onto the wood?
    Nice and traditional on the headstock - I find it easier to reach the tuners with my stub arms like this ;)
    No grain filling - straight on to the wood. I bought some proper decent cloths and decanted the oil into a plastic tub for easy application. If you have applied an oil to anything before then it's as simple as it gets - otherwise, just go easy and build up coats slowly - it really is about the most simple finish you can do.
    I used the wet sand slurry technique - basically sanding with wet and dry paper (600 then 1200 grit) with oil to lubricate rather than water - nice smooth motions up and down the grain. It's left it really smooth back and front - sides will always be less so without grain filler but they are fine. All up it's taken a day and a half to do the finish - and I have put Tru Oil on the neck in the meantime during drying.
  • WezVWezV Frets: 16809
    You may find the Danish oil continues to soak in for a while.  Sometimes the wood can start to look dry.  An occasional re-oil will sort it, or wax it now to keep it nice for longer
    Any particular wax?
    Natural briwax for me
    Thanks!
  • FunkfingersFunkfingers Frets: 14594
    How did that get past the censor?
    Thanks!
    The thing I will say is to avoid Colron.  Their was is a weird paste, not like actual wax at all.   But it is easier to find and I am sure most would assume it was a comparable product
  •  That looks superb fella. Can't wait to see the finished job.
    The Swamp City Shakers
    Following @WezV ‘s advice I’ve applied an initial coat of wax. I’ll leave it to dry, then do another coat, then buff. I’m using some posh stuff the missus has for her furniture restoration - it’s just clear natural but it does give a nice lustrous depth to it.
    Pics in shade and one in direct sunlight so you can see the colour depth:
    If I’ve learned anything since doing these projects on here it’s this: when a real expert like @WezV suggests something, do it.
    I started this project hoping for an adequate finish that wouldn’t look rubbish and would be passable for a gigging bass. I’ve ended up with probably the best natural finish I’ve ever done.
    Two coats of wax and a good buffing later (took an hour tops) and it’s taken on a lovely satin sheen.. it’s silky smooth and feels lovely to the touch. Well pleased.
    Right. First job today was to do the tuners.
    I got some “licenced by” tuners rather than the expensive Hipshot ones.
    Don’t seem too bad inside the box:
    Turns out “licenced by” screws means “cheese”
    Cue up a good hour of cursing swearing and plier action. Sheesh. And I had to find another screw...
    Anyway, fitted:
    Next job was the strap buttons. I’m fitting Dunlop’s as I have them on my mono strap, and I like them.
    Usual job of masking tape, and soap on the screws..
    Not looking bad as it stands..
  • JonHoskerJonHosker Frets: 395
    Great job ... well done!
    Finally screwed neck and body together - it’s actually a bass now!
