(formerly customkits)
I like the idea of having the angle in the pocket even though I have done the hee
on my first couple of builds
nice work indeed.
Thanks very much chaps, cheers.
Pete I reckon it could be converted to Myka-style, thought that would be a backup if it all went south... and still could be handy at some point. Seems OK though as it is, the fit's neat & tight.
One thing yet to figure out completely is propping the end of the template against flex, I used a wood wedge this time which was dead solid but the ol' brain cell is mulling over a neater idea.
of the routed pocket as the guide for the rest of the 35mm deep pocket rout
http://www.rabswoodguitars.co.uk/
https://www.facebook.com/RabsWoodGuitars/
My Youtube page
: ) Cheers Rabs
Pete, I've a couple of 32mm long cutters, 1/4 shank and 1/2 radius, from Wealden. On one I added an extra bearing to make the most reach possible.
On this body it was enough reach to leave 6mm floor at the front of the pocket. With a thinner plexi plate on the router it'd have a hair more reach, that'd be OK because it's not really going to flex here, I think that one's 12mm.
Katsu bases are like a tenner delivered so I might get another one and leave it on a thinner plexi base ready & waiting, if ever needed. Or could rout down a couple mil into that base instead, inset the router slightly.
Got the frets in, nice Jescar NS wire, in a med jumbo size (slightly wider & taller than 6150)
http://www.corvusguitarworks.com/images/lph/16-frets.jpg
And neck shaping starting
http://www.corvusguitarworks.com/images/lph/17-neck-shaping.jpg
The new jig base is dead handy for general fettling, the clamps put down a lot more force than I guessed they would. Roundover done
http://www.corvusguitarworks.com/images/lph/18-roundover.jpg
And neck glued in. 'scuse the novelty condom... helps protect the headstock corners while works going on. The lip inside the cutaway is quite thin so a couple of wedges keep it in check, just in case
http://www.corvusguitarworks.com/images/lph/19-neck-glued.jpg
http://www.corvusguitarworks.com/images/lph/20-neck-glued.jpg
Quick update, sanded & finishing started. The top has a very thin coat sanded back, I'm quite liking the natural look, but still will add some colour later
http://www.corvusguitarworks.com/images/lph/21-top-sealed.jpg
The neck went pretty orangey vs the body after the same thin clearcoat, but tinted the neck first and then the body so they sit better together. The pic's a bit darker than in some lighting but here we are.
http://www.corvusguitarworks.com/images/lph/22-back-tint.jpg
Yesterday's progress, top coloured in, binding scraped and starting to lay clear down - bit hard to photo not least because I'm terrible with a camera or phone and it changes a lot with light
http://www.corvusguitarworks.com/images/lph/23-top.jpg
http://www.corvusguitarworks.com/images/lph/24-top.jpg
My Youtube page
Feedback
Bit delayed by starting two other builds but waiting for paint to dry ..
http://www.corvusguitarworks.com/images/lph/p1.jpg
http://www.corvusguitarworks.com/images/lph/p2.jpg
http://www.corvusguitarworks.com/images/lph/p3.jpg
