The nut is too tall. This is the way most "pre-cut" nuts come. You won't need to remove the nut, and looking at the glue they used it probably won't come out easy. The usual method is to deepen the string slots with nut files
I will be covering this when I get around to doing the set-up on mine. I will then replace the nut with something better and sow how to remove and replace at that time
i would recommend getting some nut files, its extra expense but there is no easy way to do it without them. these look cheap and nasty, but will probably do for a couple of guitars
http://www.ebay.co.uk/itm/Guitar-Player-Luthier-Tools-Kit-Set-in-Nylon-Bag-Nut-Files-Steel-Ruler-Winder-/360627194194?pt=UK_Guitar_Accessories&hash=item53f70e4952
or there is this system
http://www.ebay.co.uk/itm/GuitarTechs-NUT-SLOTTING-FILE-KIT-Saw-Set-Luthier-Tool-Bone-Brass-Tusq-Corian-/281290485733?pt=Guitar_Accessories&hash=item417e382fe5
You can do it with needle files..... but it can all get a bit MDphillips if your not careful.
Instagram
Meanwhile:
https://docs.google.com/file/d/0B2EimGETSxWBdHRlOFVteXVQWFU/edit?usp=docslist_api
It's an ink stain, I'll be attempting a fade to black around the edge, and there will be plenty of sanding back and reapplying before I'm happy enough to lacquer it, but it's fun anyway.
Instagram
Chatoyancy
Instagram
experience does count for a lot...but you have just earned yourself 750xp and moved from a Level 1: Complete Newbie to a Level 2: Keen Amateur
Instagram
Much easier to see the progress when it's all in one thread! You probably don't need to sign up separately for picassa if you already have a google account, but what you can do in google drive is click the 'download the current version' button and then copy the download location that your browser gets (use your browser's 'open' option to avoid having to save another copy). That's the same thing I use when I want to share full size pictures for picassa, as the sharing links it gives you are restricted to a number of fixed sizes. The downside is you have to resize them before upload if you do it that way, otherwise they'll probably show up far too big.
