When I do, I plan to use a trimpot (mounted inside the cavity, not controllable from outside) so that I can play around with the resistance to get the sound I'm looking for.
JM build | Pedalboard plans
DaLefty
Bandcamp
Spotify, Apple et al
I ain't saying nothing without legal representation.
DaLefty
You can do that if you want, or you can dick about with the boost circuit and get 50dB out of it and not have to spend around £60.00 on two of them and have to worry about fitting two boards into your guitar, and draining the battery twice is fast, or using a battery for each board, Alternatively you can mod the aftermarket Eric Clapton Boost Circuit, it's not actually called that by the way, it called the UPC Part No. 005-757-7000, 717669160210, as it's not what Eric Clapton actually uses and several other guitar players like Muddy Waters have their own version of the circuit board, it is not what is in his signature series of strats, the ones released after 82, but you can mod this circuit to Eric Claptons specs whch will give you a 50dB boost, the cheaper route which you can do for under a tenner is the Australian guitarist Ritchie Laird's mod, here is a link to a very detailed page that he set up about that, and how to do it;
http://www.singlecoil.com/docs/active_strat.pdf
Adapting it for a Les Paul style of set up is quite simple. Then there is always the gutting a boost pedal and putting its guts into your guitar, the Mooer MBT2 Pure Boost Boost Pedal, has a tiny foot print and will give you 20dB of boost.
DaLefty
DaLefty
DaLefty
