Scratched glasses
monquixotemonquixote Frets: 17662
in Off Topic tFB Trader
Anyone got any tips for getting scratches out of glasses?
Fell over running and my glasses flew off.
Im going to need get some more, but I was wondering if there is anything I can do to make the best of them in the short term
  • octatonicoctatonic Frets: 33827
    Are they coated?
    If not then a toothpaste slurry can be used to polish the scratch out- google it.
    If they are coated then you are screwed- I buy my glasses from a place with a "free replacement lenses for scratches" policy.
  • ICBMICBM Frets: 72552
    Unlikely that you can do anything that won't make them even worse, from experience.
  • monquixotemonquixote Frets: 17662
    octatonic said:
    Are they coated?
    Where is that?
  • sev112sev112 Frets: 2791
    Just hope you haven't got a big prescription - £700 they wanted off me for that !
    "They" being a generic "they"
    That's the other problem.
    They will want about £300 and two weeks to get new lenses
    octatonic said:
    Are they coated?
    Where is that?
    I went to Ideal Eyes in Oxford.
  • KKJaleKKJale Frets: 982
    Check the prices at https://www.ciliaryblue.com/ .
    Looks good.
    I'm slightly screwed because I can't be without my glasses, but I might try them in future.
  • EricTheWearyEricTheWeary Frets: 16299
    Fenwick's Windowize - might concievably work, it's very good on scratches on plastic/ acrylic surfaces. About £6 from big camping, caravaning type places.
    Googling this seems to mostly bring up toothpaste or brasso. Seems important to have your glasses as clean as possible first otherwise you'll create more scratches.
    I've been impressed by WD40 for small scratches on laminate flooring, not really sure that works for glasses though.
  • Flink_PoydFlink_Poyd Frets: 2490
    For God's sake don't use toothpaste. It was the standard fix for skipping CDs that left them cloudy as hell.
    Nobody is guaranteed tomorrow.....
    edited June 2017
    and yet:
    http://glassescrafter.com/information/remove-scratches-on-eyeglasses.html
    You have to use a non-abrasive toothpaste.
  • ToneControlToneControl Frets: 11958
    Looks good.
    what kind are they?
    varifocal?
    T-Cut works well for CDs and DVDs, for what it's worth. I doubt it's a hard enough cutting agent for glass though.
    edited June 2017
    Most glasses aren't glass, they are plastic.
    Don't they usually have a glass (supposedly scratch-resistant) coating? Mine do.
    Looks good.
    what kind are they?
    varifocal?
    I have a really strong astigmatism in one eye from keratoconus.
    Asda do rimless glasses in any prescription (AFAIK) for £50 a pair, coated if you buy 2 (£70 otherwise)
    Normal frames start at £40
    includes tints
    I bought a load of "spares" from them
    the varifocals aren't anywhere near the quality of my fancy pricey Zeiss ones, but they are OK
    I'd get down there and order some - as spares
    you won't be able to fix scratches on a coated lens
    there are re-glazers around, I had some reglazed reasonably cheaply by http://www.reglazemyglasses.com/pack-request.html
    check out mse for other re-glazers
  • BudgieBudgie Frets: 2108
    Cutting compound? Farecla make good stuff, failing that t-cut perhaps. I know a guy who sells posh vintage pens like Mont Blanc etc who uses it to remove scratches and to polish the plastic bits. I imagine it would remove any coating though.
    I don't believe it is glass- I thought it was a different type of hardened plastic.
