Forum feedback thread. | G&B interview #1 & #2 | https://www.instagram.com/_harry_seven_/
I'm off to find it, I need to show my wife
It's started to delaminate due to water damage (left outside), so I'm wondering whether to go down the long and tricky route (steam the whole thing apart) and start reassembly with a load of bits or to look at something quick and dirty (wick adhestive into the gaps, clamp and cross fingers).
As it was outside for some time, I'm tempted to treat it with permethrin as a precaution...
It's going to be a difficult one to fix - if the wood has warped or shrunk it won't go back together properly even if you can force enough glue in, which is a challenge in itself. The best bet is probably to separate it properly, dress the faces back to straight and reglue. The thin walnut strips will need replacing. It's a huge job…
but yeah, what @ICBM said for the repair method. The thin veneers can be sacrificial.
i saw it on rlthe other FB and wondered what had caused the delamination. They are normally very stable!
Instagram
Instagram
Well, 'twas only a fiver, so worth having a play with.
In person (so to speak), it's actually *quite* solid. However...how long it will stay that way is a different matter...
I hope we may see it back to its former glory in due course....
my John Birch had water damage as well as 2 major splits in the body from an incident. I suspect it was chucked in a shed or damp loft after the initial damage. It reglued fine quite quickly.... but hiding the scar has been difficult due to the moisture fluctuations
Instagram
A warehouse in quantum superposition until it interacts with, or is observed by, the external world.
:O
Good point. Maybe do the permethrin thing, then leave it be for a while.
Did you ever finish this H?
http://www.thefretboard.co.uk/discussion/61134/sarge/p1
