Anyone had this? I get a consistent click through my amps, once every second and a bit. Nothing is faulty...it happens with all guitars, every amp and every cable I've tried. Disappears with the guitar volume down. I have an amp upstairs too and it does it with that also.
I have shut power off to everything in the house bar my guitar room, and to all devices within it bar the amp. All phones are off.
So the guitars must be picking up something from outside the house. It started in the last month or so. WiFi maybe? Power lines?
It's a pain in the arse, since I cannot record anything at the mo. It's not loud, but it's there.
Process of elimination required
with nothing plugged into the amp then is all good or still a click - regardless of low or hi-vol and again regardless of clean or gain settings
Now above with just a lead and no guitar
first thought was a mobile phone interference but you state you've eliminated this option - Not sure if wifi can cause this - I've not known it, but wouldn't surprise me either and take into account your neighbours signal is still in your house/room
any dimmer switches in the house/room - but you appear to have eliminated this option
Have you tried amp/lead/guitar in a friends house - again just trying to eliminate options
sorry I have nothing positive to add
Still can't work out who's doing it.
Definitely not a mobile! First thing I checked
I get it sometimes with single coils if I get too close to the amp at home, I thinks it's interference from something else running in the house, washing machine, dishwasher, etc. Not had it last permanently so I guess yours may be something outside your house, or interference coming in through the mains? Isn't there something you can plug into to clean up your mains? I don't know much about these kind of things really.
Does it happen anywhere else, Have been able to take your amp outside the house and plug it in elsewhere?
sorry if it appears a silly question, but assume no tremelo, or similar, on the amp - or indeed no similar pedal as such connected
On a valve amp , more so if older - the filter caps might be on the way out and can produce an oscillating 'motor boat' click but the likes of @icbm should be able to help better on this then I can
http://www.bugsweepinguk.co.uk/bug-detection-services/bug-sweep-services-throughout-the-uk
Rift Amplification
Brackley, Northamptonshire
www.riftamps.co.uk
Also, it's been there ten years and I only started noticing this noise about a month ago
