Follow the steps in the same order and it'll get you in the ballpark. Don't just randomly jump into the middle cos each step can affect the others.
You'll need a couple tools - ruler, feeler gauges. You can get these cheap from eBay.
If you do this it might take a while at first but you'll never be dependent on anyone else to setup yr guitars in the future. If all this seems like too much ball ache then take it to a luthier and get them to re-set it up again for you.
2 - I'm sure @TTony ;would try 9gag, were it not for the fact that he's one of the active owners here (I'm the other one) and this place does just fine. That tactic probably won't get you very far.
3 - You might want to look up the definition of some of the words you used. "Slander", for example; it doesn't mean what you think it does.
