String gauge
HootsmonHootsmon Frets: 15991
Age old question folks but what gauge are you using on your electric solid bodies?
tae be or not tae be
«134
    11s on everything
  • TA22GTTA22GT Frets: 362
    11-48 except Tele's when it is 10-46.
  • Fishboy7Fishboy7 Frets: 2227
    11 to 49 D'addarios.  Anything else feels weird.
  • AlnicoAlnico Frets: 4616
    10 - 52 on my Strat
    11 - 52 on my PRS
    10 - 46 on my JS100 and Audrey's Telecaster
    Hybrid 9-46 all day long.
    Except on my Tele which has 9’s..
  • richardhomerrichardhomer Frets: 24849
    10-46 on PRS, 9-42 on my Strat. I also prefer a lowish action.
    I’ve been playing for over 45 years and have no hand problems....
  • jdgmjdgm Frets: 852
    Nice to see folks going up to 11!
    I go 11s on everything electric except Strat and Tele which are 10s.
  • stratman3142stratman3142 Frets: 2206
    09 to 42 on my Strats and and Tele
    10 to 46 on my PRS and Les Paul
     I keep thinking about going up a gauge on both because I find fast picking easier on slightly stiffer strings, but legato easier with the lighter strings.
    It's not a competition.
  • LestratcasterLestratcaster Frets: 1095
    10's on standard tuned Fenders
    10-52's on standard/drop d/drop c tuned LP
    12-56's on drop c/b LP.
  • OilCityPickupsOilCityPickups Frets: 10725
    9-46 on everything electric ... usually down tuned by a semitone. I have a super light touch.
  • HysterHyster Frets: 208
    There seems to be a lot of machismo involved in string gauge choice, I honestly wouldn't have a clue if someone was playing 8's or 13's from the tone.
    I play 10's on a strat and will happily go to 9's the instant my body pushes back against me.
  • ricorico Frets: 1220
    11-54 on Gibson’s and 11–48 on fenders
  • punchesjudypunchesjudy Frets: 1031
    11s on everything
  • duotoneduotone Frets: 995
    9-42,, if it’s good enough for John5 it’s good enough for me
    I doubt many people would be able to tell many things about what's going on with a guitar tone when just listening to someone playing music, other than the very basic things like "there is a lot of overdrive" or "it's a strat". If you were directly comparing the sound of the two, though, I think you'd hear a big difference.
    Not that I think all overdriven (for example) guitar tones sound the same, just that it's unlikely we'd be able to pick out such specifics.
    I personally use 10-46 on everything (just to make things simpler really). I started off using 9's on a Strat and PRS Custom but felt the touch was too light so moved up to 10s and preferred it. When I then got LP scale length guitars I seem to find the feel totally fine with the 10s. Not sure if that works out to still have more "tension" (if I'm using the right term) than a Strat with 9s or if it's just that on that guitar I'm fine with the tension.
    If I preferred the feel of 9s I'd definitely use them. If I preferred the feel of 8s I think I'd start to pay attention to what it was doing to the tone before deciding to use them, just because they're quite a step away from commonly used gauges.
    True dat in many ways.
    Feel is personal too.
    I remember playing with 10’s on my esp’s and my fingers became so fatigued real quick when I was practicing solo stuff and bends.
    So I tried .9’s and much preferred it. Much easier to play and bend and possibly *slide on the treble strings.
    *not entirely sure about 10’s not feeling as slippy, it was many years ago.
    But on the 9’s I remember they felt too slack up on the bass strings. Fast chugging etc felt not so good.
    In came the hybrid set of 9-46’s and it felt like a great balance!
    Nice tight low strings to chug on and do some fast riffing, and nice light bendy high strings! Perfect!
    God knows if I could percieve any tonal difference. So I stuck with 9-46’s thinking why bother upping the resistance when I can just play these easy!
    Thats in standard tuning mind.
    On my tele I just stuck with its 9-42’s as its not what I’d play heavy rock/metal riffing on so its not so important the bass strings feel so tight.
    I suppose its what you get used to though as well.
    I use a heavy/stiff pick so theres not much give in it, which I imagine might make a string feel looser.
  • baldybaldy Frets: 195
    When I started playing (8 months ago) I went for 9-42"s as I thought the 10-46"s the second hand LP copy guitar came with were to heavy.
    As I improved i changed to 10-46"s on the LP.
    GAS has meant that I now have 2 LP copies & 3 superstrats.
    The superstrats have 9-42"s & the LP"s 10-46"s.
    I feel I have a heavy touch, partly because I am a beginner & partly because I have builders hands, & when I next re-string one of the superstrats it will be with 10-46"s as I now feel that 9"s are to light for me.
    All the guitars are in standard tuning.
    10-46 D'Addario on Gordon Smith and Gibson SG
    10-46 Ernie Ball on Peavey Rockingham
  • NeilNeil Frets: 3641
    Just basic 9's or 10's on Strats and 10's on Gibsons.
  • skullfunkerryskullfunkerry Frets: 4205
    Standard D'addario 10s on my superstrat tuned to E... when I was gigging with my last band I was tuned to Drop C so I used 11s. I agree with the comment above about machismo: I'm pretty sure you wouldn't tell even in an A/B test which strings I was using... having said that, I'm sure that with someone who uses less gain than me, it might be more obvious
