I have a milestone birthday later this year and I've got the green light to gift myself a special guitar to mark the occasion. I'd like to find a guitar that can give a wide range of tones capable of replacing both the Epi LP and the Mexican Strat that I have now.
I'm at a bit of a loss really where to start, never considered a highish end guitar before, or picked one up to play because I've never been in a position to buy one.
With a £2-3K budget. new or used from a dealer, what brands should at least be on my (hopefully long) shortlist to try as a do-it-all guitar?
An obvious one to look at is PRS, any others?
Thank you.
I like the neck PU tones on my LP and Strat and the bridge on the LP. I play at home for my own amusement and dabble with lots of styles (blues, rock, metal, jazz)
A PRS DGT gets you very much into LP territory - but their are no ‘Inbetween’ single coil sounds. What single coil sounds there are, are good - but lack the ‘snap’ of a bolt-in maple neck guitar.
There is an inherent level of compromise with all ‘do it all’ guitars. You need to compare a few at a good dealer and decide if any work for you.
Obvious to-try suggestions would be PRS DGT and ES-335 and maybe Collings if the budget will stretch a fraction (or go used). Or go towards a superstrat type which takes you to Suhr, Tom Anderson, etc
But the key thing is to go and try stuff and find what works for you - the player is much more important than the guitar, so find something you click with and you'll be happy. For me, that would likely mean a Custom Shop SG or a CS-336, or a really nice Jazzmaster or Strat, but I'm not you.
Or get a tele of course
My music:- https://soundcloud.com/hubobulous
The nicest two guitars I have ever played are a Suhr Strat and @peteri 's Gibson ES 330. I'd have either in a heartbeat.
http://i67.tinypic.com/4sfcdd.jpg
Tremolo (vibrato) bridge? To bigsby or not to bigsby? Etc
Pickup type, number, splits etc.
Fingerboard, material, scale, radius
Go to a well stocked shop on a weekday and try stuff.
Happy hunting
As above, you also owe it to yourself to check out an Eggle 96. The twin humbucker models have coil splits and are exceptionally versatile, the hss have stunning single coil tones in neck and middle and a great splittable humbucker at the bridge. They’re as well made as PRS too.
I find splittable humbuckers more versatile than singlecoils - you can approximate the twang and hollowness with a split but can't really fatten up or "un-twang" a singlecoil without the use of pedals.
Pickup style and placement and guitar construction have their tonal limitations, however much money you throw at them.
If you simply MUST switch between a Strat and a Les Paul mid song then you'll need some kind of compromised do-it-all guitar, otherwise just stay where you are or upgrade what you have.
If you really want to treat yourself for your birthday though, just buy a great Telecaster and you may end up not needing the other two anyway.
