I am pretty much finished on a Strat build and just starting a Tele. The Strat I thought had gone well until I tried to adjust the neck relief. It is a cheap neck and the truss rod seems to be only bringing frets 12 upwards up. Basically it is no good. I have a Tele neck ordered but will cancel as it seems cheap necks are not a good idea. Can anyone advise me of a UK (or EU if I must) supplier please? All parts was my first choice but after having one heel adjustable neck I will never have another. I don't really want to spend more than £150 on each but can do £200 if I have to. Ideally after a 12" with jumbo frets.
Thanks in advance
But if you're lucky he might be along to comment on this thread ...
https://www.wdmusic.co.uk/necks-c60/tele-necks-c215/wd-music-tele-vintage-rosewood-neck-honey-gloss-p4864
Although they seem relatively dear bear in mind that they are pre-finished. That saves at least the cost of a can of clear lacquer and a lot of elbow grease - more if you pay someone to spray paint.
I assume they're made in Asia but the quality is good.
Saying that I recently bought a new £25 neck from ebay, 2 way truss rod works perfectly, frets all in the right place etc, a fairly flat 14" radius which wasn't mentioned in the listing but suits me fine. Only time will tell if it will warp or shrink, but so far so great.
http://www.thefretboard.co.uk/discussion/61134/sarge/p1
Not sure why you only want a headstock adjuster, as it makes no difference to how the neck responds to the rod being adjusted whether it's at the heel all the headstock. Although it can be a pain having to take the neck off to adjust the rod, but sometimes you can't always adjust at the headstock easily without moving strings out the way on a Fender type neck.
Your life will improve when you realise it’s better to be alone than chase people who do not really care about you. Saying YES to happiness means learning to say NO to things and people that stress you out.
Sorry fix it now.
I just realised all the necks bar one are heel adjusters, so I thought I'd better add a couple more photos showing head stock adjustors.
