@RossYamaha there is a spelling mistake on the THR10 V.2 page, they spelt modified as modefied. Just wanted to let you know so you can get it sorted.
In other words, I didn't play with the software. But based on that, I definitely preferred the blackstar. The yammy was good, and definitely looks nicer - truly a living room amp. But having not played with the software on either, I'd suggest taking what I say with a pinch of salt and trying them both. I was really surprised with the id core 20.
Also, I only tried them as a guitar amp - I didn't put any music through it to jam to. Again, yammy may be better for that.
Interesting little amps - got some questions...
The two Marshall models (and maybe the Boogie one) in the standard THR10 appeal more than the various lower gain models in the 10C, but what's the 10 like for very clean cleans and edge of breakup sounds?
In the Anderton's vid about the 10C, it's mentioned that the clean in the 10 tends to have a bit of breakup, while in the 10C, it stays cleaner and more glassy. I'd rather have the latter in a clean sound (basically, no breakup at all, no matter how hard I play). Can the AC30 model do clean to dirty with the guitar's volume control?
I think there was mention of using the software to change speaker modelling - does that mean that any of the speaker/cab models can be applied to any of the amp models and saved as a preset? And, do the speaker models make a big difference to the overall sound? For example, if the AC30 does edge of breakup, but I prefer, say, the speaker from the clean amp, can I set it up to combine those two?
How do the preset buttons and rotary model selector interact? If I have custom presets, are they recalled by pressing the buttons? If so, what happens when I then use the rotary selector and the gains/EQ? (ie, what changes?)
How loud are these amps in the room compared to something like a 5-10W valve amp?
Nomad
Been doing some reading and downloaded the editor software (but no amp to connect to)...
Looks like amp and cab models can be intermixed. The software doesn't show the bass, acoustic and flat options - do the mic simulations appear when acoustic is available?
Found this post where somebody uses the bass amp for clean sounds...
http://www.strat-talk.com/threads/yamaha-thr10-settings-share-thread.333369/
...but no cabs, it seems. Anyone tried that? How is it for staying super clean, and how does it compare to the Clean amp model?
Am I right in thinking that the edits in the software (or when a patch is selected) change the amp in real time, and that storing is then done by holding down a preset button? In other words, no 'send to preset N' from the software?
If I select a preset and adjust one knob, does only that parameter change, or does the preset's adjustment change to match all of the knobs? Is there any indication when knobs are tweaked after selecting a preset that the stored value has been dialled in or departed from?
Nomad
Nil Satis Nisi Optimum
