I've done well losing 2.5 stone from training in the gym again about 4 years ago now. I've since kept up my training regime 2/3 times a week but I think on my non-working out days I'm not burning enough calories which is causing my weight to slightly creep back up again.
So in attempt to combat this I'm starting to do 1 hour walks at least 3-4 days per week on the days I'm not training. This is about 6500/7000 steps according to some shitty phone app I used earlier. So its taking me 10 minutes to do 1000 steps approx which is just under 3 miles.
I'm aiming to train at my new gym (the one I was using shut last weekend) 3 times per week with a good mix of cardio/weights and resistance exercises. Hopefully supplemented with the hourly walks I should see some improvements.
Are there good apps I can use to measure my steps with no bullshit adds and email sign up prompt things? Should I be walking more than 7000 steps?
It's my cousin's wedding in about a month's time so I'm looking to try to drop half a stone so I can get into my suit!
I usually run 3k in about 20 minutes at least once per week in the gym so that'll help.
I think cos of the weights I've been doing I've kinda got bulky and I don't want to be, just slim and lean really.
My diet is pretty good though to be fair, lean white meats, wholemeal carbs and lots of fruits/vegetables. Snacking on low sugar protein bars and cashew nuts most of the time. No fizzy drinks or processed foods, well not very often anyway. Usually I drink water or herbal teas (green/peppermint/camomile etc).
I've only just started doing this so it will take a few weeks to see any results.
I speak from a theoretical position only, but my understanding is gym to build strength, calorie deficit to lose weight. On your non-gym days it might just be easier to eat a bit less, or look at your calorie intake on a per week rather than per day basis etc.
Actually, you can very easily do 'intervals' in the above too ... in an hour you could do say, 10 mins normal speed - 5 mins brisk and repeat that 3 times.
You can load the rucksack with heavy books or a few bricks or large stones or weights if you have them.
Weight loss is easier to achieve if you don't set a target for it but instead, focus on the mechanism/process to achieve it. Eat less and exercise more (better) and you WILL shed pounds.
Make sure you are getting enough sleep. Sleep deprivation is a sure way to put on weight.
Also bear in mind that as you get older the way you build muscle and therefore the way you use protein will change so you need less of it. Easy on the cashews.
And use the Les Paul more. If it is anything like mine you can make it part of your strength workout.
That'll vary a little depending on how long your legs / steps are, but not massively.
Similarly, a brisk walk = 4mph, so in an hour of fast, non-stopping, walking you should do about 8k steps.
I find it has tremendous benefits to my mental health and general fitness but it definitely doesn't shed the pounds very effectively.
Also I’d query your advice on protein - need less based on what starting point?
There’s a school of thought that most people don’t eat enough - so I’d caution a statement like need less. As we age we lose muscle mass and getting enough protein is very important for maintenance of both muscle and bone, ideally from high quality sources if possible.
https://www.ncbi.nlm.nih.gov/pmc/articles/PMC4208946/
...is something I could do well to remember
TBH if you're going to the gym 3x/week and putting on weight it's probably the diet you need to look at. When I was cycling in bigger way (~100 miles/week split over 3 days usually) I could eat pretty much anything and wouldn't put on weight.
The other thing worth looking at is using a HR monitor and targeting the exercise you're doing to your fat burning zone (about 75% of your maximum HR), particularly exercising in a fasted state is good. Again, when I was cycling at least 50 of those miles would have been in a fat burning zone.
https://buildyourbody.org/fat-burning-mode/#what_is_fat_burning_
Sorry I think I mistyped my original post, I meant 1000 steps per minutes, 6000 for 60 minutes which equals around 3 miles after an hour's walking, not 10 minutes lol.
I don't think my diet is that bad to be fair, cutting down on carbs would be helpful but not ditching them completely as I need some energy to work out! I've tried measuring about half a plate's full of carbs (sometimes less) as a rough guide.
Walking with a weighted rucksack is definitely a good idea, or try to carry some heavy gear lol.
It's the choice of either eating less or burning m ore calories, as I like my food I will go for the latter haha.
I don't think I'm putting on that much weight, less than half a stone, its more to maintain where I'm at now and make sure I don't slip up. Anyone who's seen me in the past year or so has complimented me on my weight loss, I don't think I'm fat by any means. Could be muscle to be fair that showing me as weighing slightly more.
Had my first workout in my new my gym earlier that I joined, was good, built up a sweat.
