change offside back to offside, none of this crap about intent to play the ball, active/not active... it all just makes it a smeary mess.
Sorry.
On the TV (atleast) you see the Ref and TMO talking about the incident, and watching it together. Along with questions like "any reason I can't give it?"
With VAR there seems to be less discussion, its a another person making a decision, and seems to be little discussion between him and the Ref.
e.g. The TMO said that inn the Scot-FRA game, he thought the ball had been touched down for a try but he couldn’t actually see it on any clip. So it wasn’t given because the ref originally said “no try”. Yet he got loads and loads of grief and loads of column inches. There are lots more
And consequently the games are much more enjoyable to watch.
Therefore the rules are set up to allow them all to a hand-wavey degree, making the job of deciding what to do infinitely harder.
The coach explained that there's an accepted emphasis on the ish bit of Irish within the rules.
Technically, you're allowed 4 steps with the Gaelic football in your hands, or the sliotar (ball) on your hurly (stick), before you have to juggle it or pass it. But if you watch the game being played you'll see up to 8 steps being taken at times.
I wish football would hold onto that. Sadly, the coach reckons that Gaelic Games will become professional in the next decade and I suspect it will bring some of this rules debate.
You can't have these big team sports played at high pace if you want the rules to be applied perfectly.
Can't help but think it would be better if we all simply stopped watching.
There needs to be recognition of a margin of error, the equivalent of umpire's call in cricket. There are borderline decisions for things which depend on when the player's boot makes contact with the ball and when that contact ceases.
VAR playbacks need to be time-limited. If the VAR has looked at sixty seconds of replays and can't come to a decision, move on. It's not a clear and obvious error.
The handball law needs to be changed back to the old law of hand/arm to ball, not just contact.
Players can moan all they want about VAR but until such time as they stop trying to con the ref at every moment then they get what they deserve. We're approaching the point where a player, with nobody within ten yards, will boot the ball out of play and then scream at the ref for giving the throw-in to the other side. A citing officer would soon cut that sort of crap out.
