It's all subjective
Possibly missing a tiny bit of extreme top end - although I had them in a dark-ish sounding guitar. Keep meaning to try them in my ash-bodied partscaster but I don't really use that much gain these days so there's probably no need.
some people simply compare them with a 1950s-spec design and declare them as inferior, because they don't sound identical.
Of course nothing stops any single noiseless design sounding better or worse than an old-style SC
I tried SD stacks and hot stacks, wasn't really happy
I bought hot Kinmans and they were good, but a little dark in my mahogany strat, so I put in a DG20 set, which are amazing
I have EMG SAs on 4 guitars now,
I have a low-output Kinman as a neck pickup - that one is really good too, not as high an output as the stock Fender Tex one I took out, but just as good,
I put SCNs in a 2008 USA strat, they sounded considerably better than the standard USA ones. Very slightly less bass
I put SCNs in a tele, they were not as good as the strat ones (The neck one disappointed a little).
btw SCN tone improves when you get them very close to the strings. They don't pull the string, so you can get much closer
Tried N3s in my Tele, they were better than the Tele SCNs
Tom Anderson ones are OK, I prefer the SCNs myself
They don't sound the same as proper single coils - and that's okay. The best ones I've heard are also EMG's though I'm not sure which ones. They were silent and sounded quite stratty, if a little different.
The stacked passive types I've heard have never impressed me, but I've not tried any more than the standard fender ones, no Duncans or anything.
The physics means that to have a hum cancelling coil under the 'signal coil' (which is how most Strat and Tele noiseless units work) you end up with twice the amount of wire picking up the same signal. This is totally unlike a conventional 'side by side' humbucker where both coils 'sense' the string vibration pretty much equally. Therefore to achieve the same output a 'stack' pickup has to be wound much hotter. We all know what happens as you go to finer wire gauges and hotter winds, treble response tails off and mids become more prominent. Various companies try dodges to make their stacks more treble friendly: introducing lumps of steel to shield the lower coil, asymmetric coil shapes etc etc ... with varying success.
It is down to preference ... and to some extent the musical environment you work in.
I have been researching and prototyping noiseless pickups for four years and have not found any solution that 100% pleases my ears ... but my ears are a bit notorious for being hard to please :-)
They do sound different, that's all personal taste, but when other people (not you) reject all noiseless SCs as inferior without trying them I do reflect on the fact that people rarely complain that cars don't drive like those from the 1960s!
For me the hum was so annoying that I'd tolerate a slightly less attractive tone, but I believe the pickups I use now sound as good or better to me. Some folks seem to rejoice in the hum, but to me it's a veil drawn over the music, distracting from the quieter parts of the playing and the note decay
not talking about you guys on this thread - just comments over the years from various places
Eqd Speaker Cranker clone
I've three Strats and have tried a lot of different pickups in them.
All three Strats sound different in themselves and all the pickups vary (whether low noise or single) too. The art is to pick the best combination that suits your ear/style/need.
No short cuts that I've found beyond trying them in the guitar.
Equally I've never really found the language that's used to describe Pus in adverts and review that helpful - just what does "softer" really mean in any difinitive sense (for example)?
As to the noiselss point specifically, they vary in a similar range to the variation of typical single coils.
I've owned 2 u.s.a strat plus guitars and to me they sounded sterile flat and 1 dimentional
but that's just my opinion
Because both coils 'read' the strings, you get a true single coil sound with no need for messing about with 're shaping fields' and bollocks like that. The down side for the manufacturer is they involve tons more work to make! More parts, more assembly, more faff ... to the point where they become uneconomic to manufacture .... that is if you have to fit them into a Strat or a Tele form factor.
I produced a totally noiseless Tele bridge prototype ... the 'B1' that was closer than I'd ever had to a true noiseless single coil sound before. I would have had to sell them for a daft price however ... and two prototypes still sit on my shelves. Fender make a similar pickup but it sounds different as it uses a rail rather than pole pieces.
