Wonder if any of you guys could help me here. I’m not sure it’s possible without more expense but here goes.
I have two amps and I am splitting my signal using an Axess Splitter/Buffer I recently bought off the very helpful @PFAllen2. All the fx go into both amps of course (see image below). However, I would like all or at least the delay (Timeline) and modulation (Mobius) to go into one amp and the other amp dry. I use a DMC-8D and a DPC-8EZ for my switching system so how can the fx be split?
The added complication is sometimes I may go out with one amp but I would then want all the fx to go through the single amp but don’t want to have to rearrange patch cables to do that etc. Without going the down GigRig G2 route before anyone suggests it, which is out of the question, Is this at all possible? Maybe another splitter like a Humdinger placed somewhere might do it but I am guessing
By the way if anyone is puzzled the centre pedal on my board is a Wireless unit which goes into the Mobius and from there goes into the DPC-8EZ to make use of the it’s pre/post feature.
Am I maybe asking for too much? I’ll be amazed if anyone can come up with a solution.
I think you can just put a suitable splitter before the Timeline and Mobius. Then you use the "spare" output there to go to your dry amp, and the output of whichever of the Timeline and Mobius is second to go to the wet amp.
If you're only using one amp, use the wet output.
Just put the splitter earlier in the chain. Then one of its outputs goes straight into an amp and the other output goes into more effects. When you only have one amp you just don't use the first splitter output.
The chain is:
Simples!
R.
Eqd Speaker Cranker clone
Robins diagram covers it Have you tried connecting it all.
Sorry If I seem a bit dim I'm not this bad usually LOL but I'm hitting a wall it seems
So no.
If you don't believe me get a Lehl 1@3 and try it at 9v and 20v. Huge diff in clarity and headroom.
If the Mobius is first you can't un-Mobius the signal later in the chain.
If you put the Mobius second to last and the Timeline last (or vicey-versey) then it'd be easy.
It doesn't have to be there but as long as I can still use its pre/post feature ?
