Line mixers.... Whats that all about?
Hi all,
just wondering what their function is?
In a w/d/w set up is it literally to split the wet/dry balance?
If so, is there an industry standard or a magic chepo version that works?
Thanks in advance!
  • GassageGassage Frets: 31018
    Basically it means taking the "dry" signal - after going through the comps, overdrives, distortions, EQs, modulations - and splitting that signal in two before the delays. One dry line goes into the delays and the other, running parallel to it, bypasses them. The signal coming out of the delays is just the "wet" echo repeats, none of the dry. Both the wet signal dry parallel signal meet again at a mixer where they are blended together before going to the amplifiers, or in some cases, before going into more modulations, then then into the amps.
    Most of us who have done this used a simple setup like this, with the delay running through a looper pedal, like a Boss LS-2, Xotic blender, or similar. The volume pedal can be in that loop or before it. There were a few volume pedals with the loop built in too.
    There are a couple of threads here about setting up a parallel delay loop. I did one listing the different delays that have the dry defeat function and listing different types of parallel loopers.
    Out of interest how does this differ from simply using the mix knob of a delay?
    Depends which delay.
    Some are internally parallel mixed, TES, Chrono, 2290, Providence 80's delay are all par mixed.
    But, to make this work you need a pedal with dry kill: here's a list of those that do 100% wet and dry kill.
    Delay's that do 100% true wet signal only:
    Boss DD-2 (with dummy plug)
    Boss DD-3
    TC Electronics Nova Delay
    Boss DD20 giga Delay
    MXR Delay system II
    TC D-two
    Line 6 Echo Park
    Line 6 DL4
    Empress Super Delay
    Diamond Memory Lane
    Eventide Timefactor
    Yamaha UD stomp
    Skreddy Echo
    TC 2290
    Skrydstrup DDL Custom Delay
    Providence Delay 80 (with dummy plug)
    EHX Deluxe Memory Man
    Ibanez DE7
    TC Nova Repeater
    Providence Chrono Delay
    Roland RE555
    Boss DD-3
    MXR Delay system II
    TC D-two
    Line 6 Echo Park
    Line 6 DL4
    Empress Super Delay
    Diamond Memory Lane
    Eventide Timefactor
    Yamaha UD stomp
    Skreddy Echo
    TC 2290
    Ibanez DE7
    TC Nova Repeater
    Roland RE555
    sorry I'm still confused, what difference does having the delay mixed in parallel in the pedal make?
    OK, what you are doing is twofold.
    1. Because you're only getting the delay signal back you keep the core note untouched and free of clutter and ghost notes.
    2. You are removing your core tone going through ADDA's- only the trails are doing that now.
    3. You can now do stuff like sending different delays (without the core or with the core note) to different amps or record your delay on separate channels in the studio etc.
    OK I get you now, although unless you are using two delays and don't want the second delay delaying the first delay I can't see much benefit if you are using a decent delay pedal which doesn't digitise the dry signal and a mono setup?
  • Ah cool, Thanks Gassage and happy belated btw =)
    So the Timeline doesnt do Killdry? Thought that would do it for sure....
    Not sure. Probably does, yes.
    @jonnygreentrees
    Not quoting for space reasons-
    It sounds daft but it just seems to make the delays sound huge; it also means you can dial more in without losing clarity. Gilmour, Johnson, Bonamassa swear by par mixing.
    @jonnygreentrees
    Fair enough!
    Re par mixing boxes:
    Hermida
    Suhr
    RJM
    Lehle Par M and L (the best one IMO)
    Gigrig Wetbox
    Badger Schism
    Wounded Paw Blenders (4 models)
  • I think most boss delays are internally parallel mixed, with the dry signal never going through ad/da. Obviously in a studio or "big rig" environment it leaves you with less options than manually splitting the signal and routing it where you want yourself but it means your core tone isn't changed.
  • It sounds great when done properly. Like Gassage said, can sound huge.
  • Hmmm! Ive just bought a Friedman smallbox and I have a Timeline/dd3 and a Dl8 plus a power station.
    Guess I could pick up 2 Harley benton 1x12 v 30 cabs, run them through the PS...
    Which mixer would you guys reccomend? BUdget in or around 150-200? (No idea how much these things cost)
  • Jonathanthomas83Jonathanthomas83 Frets: 3483
    edited January 2017
    EDIT: Delete me.
  • ecc83ecc83 Frets: 1640
    Gahggghh! WHO drew that flow diagram?? It is ALWAYS the convention that signals move from LEFT to Right in a schematic or block diagram!
    Dave.
  • 4114Effects4114Effects Frets: 3131
    edited January 2017 tFB Trader
    Dave.
    Except on a pedal board, where the diagram shown matches the typical flow of signal on a physical setup. Makes it easier to understand for your average Joe who's setting up their board with parallel mixing.
    It's well designed for the target audience, I don't think it was really aimed at satisfying angry engineers with pedantic tendencies ;-)
    Fantastic stuff @Gassage!  Thank you!
    Another big user of the sound is Steve Lukather, he does some sort of interactive timing thing with two DL8s (modified for kill dry) and an RJM mixer.
  • Just adding a few to the 100% wet (has kill dry) delay list:
    Free the Tone Flight Time
    Source Audio Nemesis
    Strymon DIG
    Strymon Timeline
  • paganskinspaganskins Frets: 276
    edited January 2017
  • Thanks for all the info guys, Ive been wondering, would the PS do as a power amp or would It be better to get a dedicated "Stereo" amp? How would the Loop on the PS figure on the PS for a wdw?
