There are a couple of threads here about setting up a parallel delay loop. I did one listing the different delays that have the dry defeat function and listing different types of parallel loopers.
Out of interest how does this differ from simply using the mix knob of a delay?
Some are internally parallel mixed, TES, Chrono, 2290, Providence 80's delay are all par mixed.
But, to make this work you need a pedal with dry kill: here's a list of those that do 100% wet and dry kill.
Delay's that do 100% true wet signal only:
Boss DD-2 (with dummy plug)
Boss DD-3
TC Electronics Nova Delay
Boss DD20 giga Delay
MXR Delay system II
TC D-two
Line 6 Echo Park
Line 6 DL4
Empress Super Delay
Diamond Memory Lane
Eventide Timefactor
Yamaha UD stomp
Skreddy Echo
TC 2290
Skrydstrup DDL Custom Delay
Providence Delay 80 (with dummy plug)
EHX Deluxe Memory Man
Ibanez DE7
TC Nova Repeater
Providence Chrono Delay
Roland RE555
1. Because you're only getting the delay signal back you keep the core note untouched and free of clutter and ghost notes.
2. You are removing your core tone going through ADDA's- only the trails are doing that now.
3. You can now do stuff like sending different delays (without the core or with the core note) to different amps or record your delay on separate channels in the studio etc.
So the Timeline doesnt do Killdry? Thought that would do it for sure....
@jonnygreentrees
Not quoting for space reasons-
It sounds daft but it just seems to make the delays sound huge; it also means you can dial more in without losing clarity. Gilmour, Johnson, Bonamassa swear by par mixing.
Hermida
Suhr
RJM
Lehle Par M and L (the best one IMO)
Gigrig Wetbox
Badger Schism
Wounded Paw Blenders (4 models)
Guess I could pick up 2 Harley benton 1x12 v 30 cabs, run them through the PS...
Which mixer would you guys reccomend? BUdget in or around 150-200? (No idea how much these things cost)
Gahggghh! WHO drew that flow diagram?? It is ALWAYS the convention that signals move from LEFT to Right in a schematic or block diagram!
Dave.
It's well designed for the target audience, I don't think it was really aimed at satisfying angry engineers with pedantic tendencies ;-)
Another big user of the sound is Steve Lukather, he does some sort of interactive timing thing with two DL8s (modified for kill dry) and an RJM mixer.
Free the Tone Flight Time
Source Audio Nemesis
Strymon DIG
Strymon Timeline
