Souping up the electrics in an Epiphone Dot
  • CTS pots, Switchcraft jack and switch.
    The CTS pots vary in quality though. I recommend you buy from AllParts, WD Music or Bare Knuckle rather than a smaller outlet.
  • the_jaffathe_jaffa Frets: 1808
    Brilliant, thank you
  • OilCityPickupsOilCityPickups Frets: 10709
    edited December 2013 tFB Trader
    Use Bugger-Allparts for the wire too: cloth core braided outer ... don't bother with the braided stuff with the plastic core ... you can't solder it to pot backs properly without melting the insulation.
