Delays, where do you put yours?
  • digitalscreamdigitalscream Frets: 27019
    Always in the loop for me - I can't stand that grainy sound you get from putting it before the amp (since I use a lot of gain on the amp). I also don't want to have to set up separate delay settings for clean, crunch and lead gain levels, because it's a right pain in the ass.
    <space for hire>
  • CirrusCirrus Frets: 8497
    Digital delay in loop for clarity, analogue delay in front from crunchy mayhem.
  • jaytmonjaytmon Frets: 168
    Used to be last in signal chain, but ever since I've tried it in the loop that's where it has to go, before reverb, after chorus/phaser. However the FX-8 allows splitting the effects to run in parallel so reverb and delay are set to do that, though I tend to use amp reverb if I have it.
    Unless I want to make GYBE type epic soundscapes. That's a whole different ball game.
