At 12fret, from fret to bottom of strings, I measure about 3mm. Feels high to me. But felt fine prior to string change :S argh!
I'm going to probably get a tech to lower the action as I feel it's a bit high for me.
Also, these elixir nanowebs sound good but feel weird - prefer daddarios, I think..
My YouTube Channel
My YouTube Channel
It should be tiny, about 1/10 to 1/4 of the string diameter at most - Rizla paper thickness on the plain strings, basically. There should *be* a gap, but it may be so small you have to tap the string up and down onto the 1st fret to see it.
Just a piece of paper?
Out at practice tomorrow, will get onto this at the weekend 8)
My YouTube Channel
It's a very simple and accurate test because you're using the string as a straightedge between the nut and the second fret.
My YouTube Channel
My YouTube Channel
I want to get a tech to give my Larrivee the once over. I want the action to be more like that of a Martin - right now I'm exerting too much force pressing strings down.
--> Any recommendations for somebody who can do this?
My YouTube Channel
But Martins generally have medium-high actions! So if your Larriveé has a higher action than that it really does need looking at...
I honestly think the nut is a tad high and/or the saddle needs a bit sanding. Or perhaps I'm being a wuss! Will PM you
My YouTube Channel
Out of interest, roughly how much saddle is sticking out of the top of the bridge? Is there a healthy looking break angle over the saddle? And if you measure the the distance between the bottom of the D string and the actual top of the guitar (ie soundboard) right in front of the bridge, what's that measurement?
Can you post a side-on pic of the bridge (as if you were holding the guitar on playing position and looking down at it)?
My YouTube Channel
My YouTube Channel
My YouTube Channel
3rd fret capo'd:
Fret 15 string height:
My YouTube Channel
Yes... surprising how I never really noticed it much before
My YouTube Channel
I always worry when people talk about sanding down saddles without thinking about break angle or the height of the string off the soundboard. But looks like plenty of scope there.
