Your favourite boost pedal.....
HootsmonHootsmon Frets: 16013
edited July 2016 in FX
it can be a boost/OD/OD808.......it's the pedal that you put in FRONT of your very favourite overdrive pedal tae give it that certain LEG UP/extra gain required for solos...I'm also curious as tae the pedal of choice in front of the valve driven Kingsley jobs......
tae be or not tae be
  • rossyamaharossyamaha Frets: 2462
  • vizviz Frets: 10757
    Put a volume pedal (or clean boost) in the loop! It's the only way to raise volume without changing tone.
  • d8md8m Frets: 2434
    4reaction image LOL 0reaction image Wow! 2reaction image Wisdom
  • DesVegasDesVegas Frets: 4615
    My Chinese Klon clone does just the jobby
  • camfcamf Frets: 1193
    Thorpy Klone
    The only one I've ever had, so favourite by default, the EHX Soul Food.
  • HootsmonHootsmon Frets: 16013
    ^ does it have a mid hump like a tubescreamer?
  • WazmeisterWazmeister Frets: 9629
    Bearfoot Baby Pink Boost
    From all accounts, no, at least not as bad. It basically sounds like a Klon, almost exactly like a Klon.
  • CorvusCorvus Frets: 2970
    TC Spark. Lots of sound shapes to be had with the three modes & the eq.
    Ulbrick Megaladon. Daft name, good pedal. Have it on always for cleans but also has lots of level for boost.
    Mojo Hand Rook in the boost position
  • vasselmeyervasselmeyer Frets: 3674
    For just a clean boost either the MXR Micro Amp or the Xotic EP Booster. For a mid boost with some grit is has to be a TS. If you want a combination of both with options to switch bass, treble or mids along with gain then the TC Spark Boost is hard to beat.
    edited July 2016
    Catalinbread echorec has a colorsound power boost as a preamp circuit. I've turned the preamp up high so it drives the pedal after it (mesa tone burst). I have it in buffered bypass, so the boost is always present.
    That's why I have my delay so early in my chain. Sounds great used like that.
  • mike_lmike_l Frets: 5700
    I do like the standard SD-1 or the MXR GT-OD in front of a dirty amp for extra gain/volume.
    I like the MXR Microamp in the loop for a volume only boost.
  • gubblegubble Frets: 1763
    The Boss SD-1 it's brilliant for so many things including a boost
  • simonksimonk Frets: 1467
    Suhr Koko Reloaded is the gold standard for me I think - very useful. Suhr's Dual Boost is also excellent.
    In my case the volume knob gets used as the main solo boost.
    Failing that, the SHO does a pretty good job.
  • JalapenoJalapeno Frets: 6402
    Xotic EP - lights up anything downwind of it !
    Feedback
  • NotNowJohnNotNowJohn Frets: 187
    Cornish TB-83 Extra or Catalinbread Naga Viper.
  • Moe_ZambeekMoe_Zambeek Frets: 3431
    TB83 extra is a good call, though I A/B'd mine with my pedalworx McBoost and it sounded essentially identical, except the McBoost cost less than half what the Cornish did. I sold the Cornish and have had the McBoost for probably 10 years now.
  • JD50JD50 Frets: 661
    DOD 250
