Your favourite boost pedal.....
    Sd1w
  • stefken147stefken147 Frets: 51
    I picked up a Caroline Icarus cheap a while back and love it. Had used the ep boost side of a Rook Royale before that.
  • Super Hardon or Klon
  • Ro_SRo_S Frets: 929
    For just a clean boost either the MXR Micro Amp or the Xotic EP Booster.
    I wouldn't describe either as ''clean''.   Both impart something on the tone.  For a real clean boost one needs a transparent volume boost type pedal.
    over 20 effects pedals FOR SALE, click here to see my classifieds thread.   My trading feedback
    Effects for Me & my Monkey
    YouTube channel     Facebook         Fretboard's "resident pedal supremo" - mgaw
    edited July 2016
    +1   for the TC Spark Booster
    It's a very versatile pedal and boost.   Clean boost; dirty boost;  light overdrive; plus EQ.
  • ChrisCox1994ChrisCox1994 Frets: 371
    fulldrive 2 in comp cut. never fails as a boost, or a klon clone
    https://www.gbmusic.co.uk/
    PA Hire and Event Management
  • nickpnickp Frets: 183
    another +1 for the spark booster
  • RandallFlaggRandallFlagg Frets: 14002
    edited July 2016
    J Rockett Archer, huge level of volume boost available compared to other pedals I have tried
  • hubobuloushubobulous Frets: 2368
    Suhr Koko - normal or Reloaded. My fave pedal, let alone fave boost. Clean and mid boost in one pedal, separate levels, just awesome
  • TheMarlinTheMarlin Frets: 8075
    Barefoot Red Rooster, and Mooer Flex boost.
    I I like the Moore for two reasons. Small footprint, and I use it to drive the tubes in my reverb tank, to push reverb tone 'forward', add bass, and a touch of hair.
    Tone is much less washed out and more 'present' for surfy stuff
  • therose789therose789 Frets: 467
    I like a good super hard on - oooh errr Its one of those pedals that i like to leave on, it just adds some niceness to my signal.
    However, I am currently using a sick as after a ts808 for a volume boost or just a to push my clean amp into compressing. Sounds lovely!
  • EskiEski Frets: 35
    I use a Barber Trifecta as a boost with a Crunch Box - does change the tone but I like it.
  • DesVegasDesVegas Frets: 4625
    I have a super hard on always on as mentioned before and a Klone to push my rat when a boost is needed
    I think you can get medication for that these days.
  • oafoaf Frets: 301
    DIY Ramrod Boost. SHO inspired: small and a lot cheaper though!
    OT but this was my first go at acid etching.
  • dilbertdilbert Frets: 203
    Another vote for a Mooer, this time the Pure Boost, I use mine into the front end of my Laney to just move it just into crunch territory and it really shines there.
    I also have a soft spot for the LPB-1. I bought mine for buttons purely on a whim and thought that was decent too if you just wanted a tad more boost. Worked well in the loop too but not as flexible as my Pure Boost.
    Suhr Koko Reloaded or MXR Micro Amp +.
  • The boost half of my JHS Kilt works beautifully on its own. I have a Dr Scientist Cleanness at the start of the chain, and the pedal is a work of genius.
  • lukedlblukedlb Frets: 488
    I use the Kingsley Bard (tremolo) as a boost (thanks to Simon at Kingsley, I'm going to mod the footswitch to Tremolo/Boost) to push my amp. A compressor before the Bard sends the Bard into a fantastic overdrive.
  • mburekengemburekenge Frets: 1074
    Xotic RC
