Just bought some HS-7's off ebay...problem!
  • RiftAmpsRiftAmps Frets: 3180
    Simply squirt some contact cleaner inside the hole and work a jack plug in and out a few times.
    Rift Amplification
    Handwired Guitar Amplifiers
    Brackley, Northamptonshire
    www.riftamps.co.uk
    I'm sure to give that a try mister! thanks for the tip! Will fairy liquid do ? ;)
    Contact cleaner. Something like Deoxit.
  • SporkySporky Frets: 28666
    siraxeman said:
    That's way too expensive!
    Isn't trying-to-save-money how you got into this?
    yeah I saved £120 now lol....but are you telling me that the contact cleaner spray I linked won't do the same job ?
    I don't know; I use Deoxit. Which definitely will do the job.
    Any contact cleaner will do tbh
    be liberal with the stuff it's ok
    they generally come with a wee straw to get those hard to each places
    Don't just shove it straight to the bottom and squirt
    run it up and down the socket in a swift in and out motion until it runs out the end
    Then get some contact cleaner and fix your speaker
    Cheers guys hopefully its just that simple - a bit of contact cleaner to do the trick. Be delighted if that's all it is.
