Where should i put the Octavia in the chain ?
catdogcatdog Frets: 124
  • Moe_ZambeekMoe_Zambeek Frets: 3431
    Probably before the wah if it's not a buffered wah?
  • catdogcatdog Frets: 124
    its not a buffered wah Moe but the small blue box is a buffer
    i have the buffer before the Keeley Monterrey but after my drives
  • lukedlblukedlb Frets: 488
    After fuzz? How's the chase tone?
    Love the chase tone Luke it will probably never leave my board & is always on .
    it has fuzz on it too
  • LoobsLoobs Frets: 3843
    edited August 2016
    I can think of somewhere you should put it.
    No, really, first in the chain.
    awe its poor boobs again lol , good luck with your timmy search boobs
    i tried it first but not sure i like it there
    moved it inf front of the wah but after the small buffer & it seems to be happy there but thanks for the help guys
    still not sure if the chase tone is in the best spot either but it sounds fantastic so i will probably keep it there
    My gf said the same.
    Ah thank you very much!!!!
  • I've got a Skoda Octavia just saying
    2reaction image LOL 0reaction image Wow! 2reaction image Wisdom
  • AlnicoAlnico Frets: 4616
    I would put it with the drives, probably first after the wah.
    Just spent a while looking at the pedals, that's quite a board you've built.
    Where is the ditto in the chain?
    edited August 2016
    i have the ditto at the very end if my chain Alnico
    If you experiment with it earlier on in the chain, you can get some interesting effects, so basically it will only record what's in front of it but whatever it outputs to can then be switched in and out.
    So if it's before the flint you can record a phrase and then add or remove the effects after it as it plays.
    They're loads of fun to create with.
    How's the switches holding up?
    ahh very interesting Alnico i will be giving that a try for sure, switches are good so far buddy no issues at all & i have been using it for around 4 months
    The only thing that seems to bother me is when i engage the looper to record. to my ears everything seems to go slightly louder no matter where the level is set , i dont know if this is a firmware issue as i have not tried to update it yet or its just the way the looper works , have you or anyone else heard of this ?
    cheers
    or could the above issue be down to where i have it in the chain ?
  • axisusaxisus Frets: 28347
    8th
    axisus said:
    8th
    haha that just may work
