No, really, first in the chain.
Ah thank you very much!!!!
Just spent a while looking at the pedals, that's quite a board you've built.
Where is the ditto in the chain?
So if it's before the flint you can record a phrase and then add or remove the effects after it as it plays.
They're loads of fun to create with.
How's the switches holding up?
The only thing that seems to bother me is when i engage the looper to record. to my ears everything seems to go slightly louder no matter where the level is set , i dont know if this is a firmware issue as i have not tried to update it yet or its just the way the looper works , have you or anyone else heard of this ?
cheers
