Rewiring your pedalboard - just kill me now
  • I do like the challenge, but my latest one went a bit far in that direction. I mean...it has a tuner, a phaser, a boost, a delay (Eventide Timefactor), a MIDI relay box and a MIDI controller on it.
    Because of issues caused by various units, it actually has three bloody power supplies. As well as two MIDI cables, a daisy chain power connector, several other power connectors, far more cable ties than I'd like, a significant excess of velcro and an investment of about two hours of swearing and general disappointment..
    welcome to my world.
  • The last time I rewired my board, I got a massive drop in volume compared to direct into amp.
    Have pulled it all apart again, and testing by adding one pedal at a time. Currently back up to 12 pedals wired up, and working well..... Except for reverb...my 5E3 hates my valve reverb tank, and my reverb pedal. Throws a hissy fit when I attempt to add them in. My 65 Amps Lil Elvis is better behaved....
  • SporkySporky Frets: 28934
    D'you know how long it takes to swap pedals around in a Helix?
    Seconds.
  • Do you know how much line 6 products are worth 10'years after release?
    i can pickup up a mint Flextone 3 for £50.
    M ;)
    Resale isn't rock n roll. :p
    It's accountancy. B)
  • digitalscreamdigitalscream Frets: 26940
    edited September 2016
    That can all be resolved though, surely? My board runs off one plug.
    I've tried an isolated supply - without spending a fortune, I can't get one which has enough juice to power the Eventide, and the Peak MIDI controller seems to cause massive noise whether isolated or not. I guess it depends on whether the supply is transformer-isolated or otherwise; three supplies is fine, though, given that it's about £100 cheaper than a supply which fulfils all the criteria.
    <space for hire>
  • Ah yes, it was never going to be cheap to resolve
  • Indeed. Ultimately, it's also a vastly better solution than the rack which it replaces. An extra couple of mains plugs is still vastly more convenient than the rack that the board replaces :)
    <space for hire>
  • TimmyOTimmyO Frets: 7621
    I've got more money sunk in to power supply/isolation/voltage switching than many people have on their entire boards #isthereanembarrassedsmiley?
    Red ones are better.
    is there anything on your board that cant be powered by an eventide powerfactor?
    I am going to guess you have gone gigrig?
    I did get close to going for a Powerfactor 2 at one point
    Guitar direct into hot amp, that's rock n' roll
    Yes but we can't all commit to the Rock and roll lifestyle the way you have Sporky :-)
    :dissapointed:
    It's all thanks to my dear departed dad's sound financial advice.
    He was an accountant.
