New Amp Day....
  • ESchapESchap Frets: 1428
    Looks all original bar the two blue mains caps.  Is it properly earthed and the "death cap" removed??
  • GassageGassage Frets: 31020
    Death cap?
    Old fenders had a cap in the mains feed.  If it goes, then you can have a live chassis - not good.  May well have been removed, but it should have a 3 core mains lead and the earth wire of the three should be firmly attached to the chassis.  If not, get it sorted, you won't de-value the amp.
  • ICBMICBM Frets: 72795
    edited September 2016
    Gassage said:
    Death cap?
    Is there a cap from the ground switch to the chassis? If so, you need to remove it and fit a 3-wire power cable so it can be earthed properly. I can't see it but it's probably hidden behind the switch if it's still there.
    They're so called because if the cap shorts, depending on the switch position the amp chassis could be connected directly to the mains live, and so will your guitar strings. You might want to avoid that :).
    If you're really set against changing the mains cable, at least have the cap replaced by a modern 'Class Y' type which are purposely designed for safety-critical applications which could lead to a shock hazard and are guaranteed to fail to open-circuit rather than a short.
  • West Midlands emergency services on standby...
  • capo4thcapo4th Frets: 4437
    Model ? Blues Deluxe?
  • merlinmerlin Frets: 6789
    So my Tweedy Deluxe that I bought from @Trude at the beginning of July is the single most amazing amp I've owned so far. Point to point hand-wired and a really good late 50s Tweed Deluxe copy. Cleans up like a dream from the guitar and has a really versatile array of tones available, and to top it all...ALL my guitars sound amazing through it. Plus it's as light as a feather.
    I couldn't wait for/afford a genuine one, and I think I've got an absolute peach. really high quality components etc etc blah, blah.
    @Gassage, please post some sound files or videos as soon as...we need to hear it!
    And once again, congratulations!
    Did anything else survive the fire? And I use the term survive loosely, obviously..
  • @Gassage ;
    how does it compare to the 57 Deluxe you sold to me?
  • LewLew Frets: 1657
    Fuck yea
  • tone1tone1 Frets: 5192
    I take it that this wipes the slate clean in regards your Mum voting Brexit?
    Amp looks cracking! Enjoy  :)
    TheMarlin said:
    @Gassage ;
    Paul,
    A deeper fix of the same flavour. Insanely dirty.
  • Sweet! Congratulations :)
    Johnny
  • ruomaruoma Frets: 67
    Is that Jensen an alnico speaker? How does the speaker compare to the j20's blue?
  • Very very nice - some old tubes in there too?
    Respectfully, how can you compare a 58 year old speaker with a new one?!
    Well, I would think of things like response, feel, attack, tightness, bottom end etc.
    Hmmmm- well, it's tough to describe- the whole amp is as dirty as hell. The speaker, so all have told me, is the abolsutely key. It's warmer than new ones for sure. Headroom isn't a feature of this amp- it's designed to be dirty
  • RiftAmpsRiftAmps Frets: 3184
    @gassage has it been reconed?
    Rift Amplification
    Handwired Guitar Amplifiers
    Brackley, Northamptonshire
    www.riftamps.co.uk
    Chris- how would I tell other than taking it out? Not sure.
