Tell me I'm missing something obvious? !
sgosdensgosden Frets: 1995
edited October 2016 in Amps
Just bought myself a Victory VX kraken, sounded bloody amazing in the store...
But I get it home, and I can get nothing out of it at all!
I've tried 3 speaker cables, 2 intrument leads in, and all 3 outputs (8s through an 8 cab, 16 to a 16 cab) and NOTHING!
I've put it on high and low mode, taken volumes and gains off 0.
Please tell me I'm missing something bloody obvious. It's litterally been sat in in carry bag in the boot of a car for a gentle 90mins.
I just want to play with my new toy
«13
  • SporkySporky Frets: 28937
    Have you plugged it into the mains and turned it on?
    You did say obvious...
    Also does it light up at all?
  • sgosdensgosden Frets: 1995
    Haha, yeah the missus even commented that the purple light was nice !
  • stratman3142stratman3142 Frets: 2218
    edited October 2016
    With a guitar lead attached but not connected to the guitar does it buzz or make a noise when you touch the end of the jack plug?
    It's not a competition.
    With a guitar lead attached but not connected to the guitar does it buzz or make a noise when you touch the end of the jack plug.
    no, no buzz atall, tried with a few leads too.
    edited October 2016
    I've just looked at the manual on line and it might be worth checking the HT fuse.
    HT fuse looked intact when I took it out, but will check with the multimeter when I'm home again.
  • ESchapESchap Frets: 1428
    Try going in through the loop.  Should tell you if the preamp or power amp at fault.   Could easily be just a valve fail.
  • paul_c2paul_c2 Frets: 410
    Could it be that a valve has come loose, and needs reseating?
  • tone1tone1 Frets: 5198
    Try swapping guitars maybe
    So,
    1) check HT
    2) go through power valves
    3) check valve connection
    4) if nothing works, cry and eat icecream
  • ICBMICBM Frets: 72845
    5) buy Peavey Bandit, forget about amp reliability problems for ever.
    I think there's one for sale on this very forum...
  • OK, here are the things I've known people to do with these, which all resulted in them feeling very silly afterwards:
    1 - Not flicked the switch on the front panel (yes, really)
    2 - Plugged the footswitch into the FX Loop/Solo Override socket, and left the FX loop switch on the floor unit disengaged while having nothing in the loop (just unplug the footswitch to test)
    3 - Got the loop send/return the wrong way round
    <space for hire>
    definitely flicked the switch,
    Haven't taken plugged footswitchin yet,
    Not plugged anything into the loop in/out,
    May be worth putting a patch cable accross the fx loop
    Fuse is fine,
    No output when plugging into fx return,
    Valves seated fine.
    Arse.
  • the_jaffathe_jaffa Frets: 1814
    Could it be that you've not posted in the correct forum? That might help  :) ;)
    posted in "amps" ? Seems fitting?
    I'm was sure it was in the for sale section. My mistake if not
  • monquixotemonquixote Frets: 17736
    edited October 2016 tFB Trader
    Well I suppose technically it's not actually amplifying anything so he may have a point.
  • Have you tried turning it off and on again...?
  • fretmeisterfretmeister Frets: 24733
    Have you tried a different power cable? Can't see you've mentioned it.
