Kettle Leads
DeijavooDeijavoo Frets: 3299
Left both behind at a gig last Saturday night. One for my amp, one for my Voodoo 4x4.
Does it matter which brand or spec I buy? Wanting to buy pretty long if I can for the amp as we jam in a decent sized venue.
  • monquixotemonquixote Frets: 17714
    They are all the same, don't bother buying an expensive one.
    ..zackly!!
  • DeijavooDeijavoo Frets: 3299
    Spot on, cheers.
    Marlins it is!
    I presume that the length doesn't cause any problems?
  • octatonicoctatonic Frets: 33866
    Deijavoo said:
    Marlins it is!
    You can use a very long cable for AC power and not have any issue.
    Same with speaker cable.
    Unbalanced instrument cable is the one you want to be careful with in terms of length.
  • Danny1969Danny1969 Frets: 10489
    The cheapest chinese one's are made of a harder material that doesn't grip as well as a good quality softer one. Still unlikely to fall out though unless used on a bass amp.
    I recently chucked away about 20 kettle leads as you inherit too many in the repair business.
  • p90foolp90fool Frets: 31746
    Just make sure it's not literally a kettle lead, some plastic kettles used to use 2-core, I don't know if that's still the case.
  • ICBMICBM Frets: 72780
    I'm pretty sure these don't have the third hole in the plug, so they won't physically go into the socket. I have one like that on my workshop vacuum cleaner too.
     Ive never had any complaints
  • RiftAmpsRiftAmps Frets: 3184
    edited November 2016 tFB Trader
    Rift Amplification
    Handwired Guitar Amplifiers
    Brackley, Northamptonshire
    www.riftamps.co.uk
    Just make sure the cables are absolutely straight and raised about an inch above the ground by resting them on acoustically tuned bamboo blocks.
    5reaction image LOL 0reaction image Wow! 2reaction image Wisdom
    That is only an issue with digital devices, because they run on binary.
    The 0's are fine but the 1's have a little hook on them- like this:
    The 1's can easily get caught up if the cable isn't straight enough.
    And as we all should know by now the real information is contained in the 1's- the 0's don't mean anything.
    8reaction image LOL 0reaction image Wow! 1reaction image Wisdom
  • slackerslacker Frets: 2262
    I checked out the cable link good grief! And I thought us guitarists were gullible.
  • RockerRocker Frets: 5005
    You sound like you know what you are talking about. Is the lower slot to break up resonance?
    Nil Satis Nisi Optimum
  • SporkySporky Frets: 28879
    The lower slot damps micro-vibrations which can collapse the crystalline quantum states of the music, resulting in it becoming deterministic, lacking in free harmonics and thus unexciting to the ear.
  • GassageGassage Frets: 31019
    I have some Pete Cornish ones going spare.
    £95 each to you.
    £95 each to you.
    How much for a toe?
    octatonic said:
    £95 each to you.
    How much for a toe?
    He will do one for you but you need to provide a black label MIJ toenail with your order.
    Gassage said:
    octatonic said:
    £95 each to you.
    How much for a toe?
    Can I substitute an MJJ toenail?
    I hear they are bad, real bad, shamone.
    octatonic said:
    Gassage said:
    octatonic said:
    £95 each to you.
    How much for a toe?
    Green Labels are often gangrenous.
