What is the most versatile guitar?
12346»
  • I don't really get the HSS thing...I don't really hear much difference between a single coil in the bridge position and a humbucker
  • You're doing it wrong then ;)
  • ToneControlToneControl Frets: 11975
    VG strat
    Real USA strat single coils
    then simulated strat, tele, HB, acoustic, all in normal tuning, Open G, dropped D, DADGAD, baritone and 12 string
    edited January 2014
    but you mean analogue pickups I guess:
    in which case EMG 89 on bridge and neck,. an SA in the middle if you like
    Active bass and treble EQ
    89s can do EMG 85 sound, or SA sound. They are amazing
    and stick a piezo in too
    in fact, that means it's this guitar:
    http://www.steinberger.com/tech20080007.html
  • Strat or tele I reckon, based on the amount of times I've seen/heard them being played in various styles of music. Personally I'd rather have a single coil bridge pickup than make do with the sound of a split humbucker, but that's just because I don't play very distorted stuff.
    335s can also do most styles pretty convincingly - nice balance of twang and fatness.
  • bertiebertie Frets: 13570
    ICBM said:
    NPP said:
    just (physically) swap the neck and middle pickups. This should give you m - m+n - n - n+b - b on the 5-way switch.
    I know -
    wouldnt a RW/RP  in the middle fuck all that up tho ?
    I just used a schaller mega E........about £7 I think
  • ICBMICBM Frets: 72646
    That's why you have to physically swap the neck and middle pickups, not swap their connections on the switch.
    I would use a proper Superswitch, but the guitar is a Japanese Aria with the short-frame switch, so it won't fit. It was hard enough to find a standard 5-way that did!
    EMG 89 is not a split HB in the same way, different magnets I assume, SC mode sounds like SC much, much more than normal HB efforts.
    the Suhr SSV split is a pretty good imitation of a true SC, btw, but I know what you mean, most HB sound nothing like a SC when split
    but then the "neck" in the midldle would cause pos 2 issues with the bridge surely ?  or are you saying you dont use that so its irrelevant ?
    edited January 2014
    The whole point is to get rid of the bridge/middle setting :). The only time I ever use it is with a lot of distortion, where I need hum cancelling and where the dirt covers the actual tone enough that I can stand it… although I still have to roll the tone control down a bit.
    What I really want - and which is easy with a Superswitch, and so is frustrating that the Aria can't take one (and I'm not going to hack it!) - is:
    1 - neck
    2 - neck & middle in parallel
    3 - middle
    4 - neck & bridge in parallel
    5 - bridge & middle in series
    That would be quite versatile.
  • luscombeluscombe Frets: 155
    Although it hasn't been mentioned yet, a gibson 355 with the variotone contol gives an incredible range of tones if you just sit with a guitat and amp and gpo through all the permutations. In a live evornment it doesn't seem to work out that way, and very few players seem to use all the tones available from the Variotone unit (thin 'Strat tones are easily found).
