Instead of $99 with the full Helix, its will be $299.
Not seen officially yet, but have seen it on a couple of forums
Yep and here, already posted it on page 1, read from the link you posted!
So so far the updates have been really good for feature additions
Yeah, although I didn't like his sleeve tattoo.
Makes him look cheap.
so you have a visual display of what switch is doing what.
makes sense as the main display is a bit redundant during a live performance
it looks clever
Somewhere on Ebay luminous, sticker labels are available to buy, I got some for my GT100. It looks great, I can't afford one or justify one but I'd really like one. Maybe in a year or two.........
Ohh it does amp channel switching too! They kept that from the full fat version, nice touch.
https://www.thegearpage.net/board/index.php?threads/helix-lt.1812620/page-3#post-23860021
Which also means the AX8 and FX8 have just taken a kick in the balls IMO
Good work by Line 6 here to bring out a low fat model of the Helix, it makes total sense for anyone who needs a simpler ride - possibly ideal for gigging?
Am seriously trying to weigh up how much I'd miss scribble strips and more loops. I think actually quite a lot. Hrmph :-s
The scribble strips are nice though; I think they're worth it if you use a lot of patches with different footswitch assignments. If you can be a bit more organised so each footswitch does a similar thing in all your patches (fer example, FS1 is always dirt, FS5 is always modulation) then you'd be fine without scribbe strips.
As for the loops, that depends. What would you be sticking in there?
From a gigging perspective, helix doesn't have anything that is weak enough that I couldn't just use on-board sounds... however the loops are useful for recording or home use, when you want to add in specific pedals.
No question for me, this is the version of helix I would prefer to have if I was buying now.
Loop-wise it's really just whether I might want to use 4cm plus my Rat and homemade boost all at once and all in different places, but honestly I probably don't need to, not least because I've literally never used an fx loop in my life. I don't have anything else fancy that the Helix can't do itself. I really want to have a go at the Deco/Mimiq, double-tracked thing but half the attraction of the Helix is that I could build something that would do basically that anyway.
I was also wondering about the loss of the mic preamp in relation to recording acoustics, but since I don't have any microphones and my acoustic has a Baggs active pickup in it I can't see that being a problem. I literally never record anything at the moment, so I don't think that's something I should be worrying about right now. I'm being silly.
The RAT block in the Helix is ace and there must be twenty ways to do a boost with whatever flavour you want.
Well, you could potentially have both the rat and boost in 1 loop and still use loop 2 for the 4CM.
Not sure how well you'd get the double tracked sound out of helix, but who knows they might put in an fx block at some point.
You could also use an IR to make your Baggs sound more natural, I've had some good results with the free taylor IRs that are floating about.
2 Sends/Returns as opposed to 4 (can be stereo linked)
