Boost without increase in top end presence or mid hump ?
TelejesterTelejester Frets: 743
There are so many pedals out there that give a mid boost or increase in top end presence when engaged and this is precisely what i dont want. Could you suggest a boost pedal or overdrive used as a clean boost that simply adds transparency,  thickness and sustain without tubescreameresque mid hump or added top end sparkle ?
  • LebarqueLebarque Frets: 3903
    Timmy
  • BeexterBeexter Frets: 617
    I'd be tempted to try a compressor, particularly if sustain is an issue. Suhr Koji or Xotic SP would both work well based on my experience.
  • RandallFlaggRandallFlagg Frets: 13959
    With the gain dialled back to zero a JRAD Archer (or other Klone I guess) can be used as a great boost as it has huge headroom, more than any other pedal I've tried. Dial in a little gain and it will start to colour your sound but in a really nice way.
  • nick_snick_s Frets: 138
    Or how about a multi band EQ, and just raise each frequency equally, thus boosting across the entire spectrum.
    - Shine On You Crazy Diamond -
  • vizviz Frets: 10725
    Keeley katana mini. One knob: volume. Put it in the loop.
  • fretmeisterfretmeister Frets: 24641
    Suhr koko boost on the flat setting.
  • EQ pedal.  Because you'll possibly find you didn't want to boost the lows equally depending on what tone you're trying to make louder, but you can do a flat boost on the ones that have overall output sliders (I think the MXR 10 band does).
  • CarpeDiemCarpeDiem Frets: 294
    I agree with @guitarfishbay in that an EQ pedal (with a volume/level control) should work as this will allow you to adjust the EQ. Other options include MXR MC401and TC Electronic Spark Booster.
  • JohnPerryJohnPerry Frets: 1622
    Rc booster
  • timhuliotimhulio Frets: 1286
    edited April 2017 tFB Trader
    MXR Micro Amp. Even the venerable Electro Harmonix LPB-1. Both good boosts with pretty much flat frequency response.
    Closer to home, there's also this guy if you want the option to add a bit of 'hair':
    http://www.fredric.co.uk/accomplished-badger
  • simonksimonk Frets: 1467
    Magnetic FX Zola will do what you want. Treble, bass and boost controls plus a switchable buffer.
  • Ben8010Ben8010 Frets: 150
    Another shout for the MXR Micro Amp
    Yeah I'd do this. Transparent boosts will always seem to add some brightness, although it's probably a by product of just being louder that it seems brighter - an EQ would let you boost what you want more of and not boost/cut the stuff you don't.
  • David5150David5150 Frets: 118
    Plus one for an EQ pedal
  • Winny_PoohWinny_Pooh Frets: 7802
    IIRC Boo do a straight clean boost for very cheap.
  • Another vote for EQ pedal. They're useful for all sorts of things, so worth having one anyway.
  • saint_iveysaint_ivey Frets: 17
    edited April 2017
    I use an Xotic RC Booster. Seems pretty transparent to my ear and no top end or mid boost.
  • hubobuloushubobulous Frets: 2352
    I'd also agree with the EQ pedal approach for this
  • Dave_McDave_Mc Frets: 2371
    Do you have any buffers (or always-on pedals) in your chain? If you don't, pretty much any boost will add brightness because you're effectively now running a buffered signal which will add the high end back in that you lose from long cable runs.
    Possibly, but also the buffer thing I mentioned above.
  • ricorico Frets: 1220
    Suhr Kokoboost on the full boost setting. This is an awesome pedal that is basically two great boosts in one.
    The full boost setting is a simple one knob affair but the mid boost setting has three 'flavours' and you can change the mid focus for each.
