Closer to home, there's also this guy if you want the option to add a bit of 'hair':
http://www.fredric.co.uk/accomplished-badger
Yeah I'd do this. Transparent boosts will always seem to add some brightness, although it's probably a by product of just being louder that it seems brighter - an EQ would let you boost what you want more of and not boost/cut the stuff you don't.
My music:- https://soundcloud.com/hubobulous
Possibly, but also the buffer thing I mentioned above.
The full boost setting is a simple one knob affair but the mid boost setting has three 'flavours' and you can change the mid focus for each.
