God-awful guitars
  • LixartoLixarto Frets: 1618
    ThePrettyDamned said:
    They just look naff unless Tony iommi is at the wheel.
    They have a wheel?
    No wonder they're ugly.
  • This thing looks like a flattened bulls bollock with a neck and pickups, blergh
  • dogloaddogload Frets: 1495
    Your knowledge of bovine anatomy does you credit!
  • blueskunkblueskunk Frets: 2909
    Sunburst strats with maple fretboards - grim.
    Thats one of my gods that is :-/
    I like the thinline in the first post. Hate those neon vomit Ibanez jobs. Hate all the BC Rich stuff..
    Used to detest SG's, but now I really want one..
  • IslandapeIslandape Frets: 64
    edited January 2014
    Sooooo, I thought of the most bonkers combination and Googled it...
    Wow, that sounds really great! It helps he's obviously very good with a Floyd.
  • Panama_Jack666Panama_Jack666 Frets: 2989
    edited January 2014
    Isn't this similar to what Grestch have just released?
    Yes, yes it is...
  • BucketBucket Frets: 7751
    @octatonic
  • impmannimpmann Frets: 12694
    Arrrrrggggghhhhhh Floyd Rose. Yuk.
  • octatonicoctatonic Frets: 33870
    edited January 2014
    It is an ergonomic guitar made by Texan luthier Chris Forshage called an Orion.
    I own that specific guitar and it is one of the best playing/sounding guitars I own, with incredible balance and ergonomics.
    It is also the instrument that got me into guitar building.
    edited January 2014
    Yes, yes it is...
    I know but a Floyd?  On a gypsy Jazz Guitar? I can sort of see a Bigsby making some sort of sense but a Floyd on a Selmer is like inflatable false boobs on Hercule Poirot.
    edited January 2014
    HUH?
    Not at all.
    I don't see how anyone can possibly consider giving a bit of info about a guitar 'an escalation'.
    If meltedbuzzbox doesn't like it that is fine- but there is more to that guitar than how it looks.
  • Paul_CPaul_C Frets: 7871
    ICBM said:
    http://www.rockin-chair.ch/Pics/aarc/origs/Showcase/Parker_Fly.jpg
    I loved the concepts behind this when it came out - lightweight body, resonant 'exo-skeleton', could do acoustic sounds… and I assumed that the god-awful ugly shape must have some sort of ergonomic benefit which justified it and I would eventually see it as quite cool, if never 'beautiful'.
    Then I played one.
    Pointlessly uncomfortable - that upper horn digs you in the sternum where you really don't want it to (even if you aren't female - I can only imagine it's worse having watched a friend of mine try to play one), the tone was thin and artificial-sounding or nasal and honky depending on how you set it, and it won't even hang on a standard wall hanger without probably breaking the top E string and risking the whole thing falling to the ground. You can't even put in less horrible-sounding humbuckers easily because they used a custom baseplate mounting. And apparently the glued-on frets have a habit of coming off.
    Fail, in just about every way possible.
    I'm just about to have my third attempt at re-attaching a couple of frets to a Fly (I can't get the exact glue they recommend, and have already tried two of their suggestions with no joy) so I'd agree that it was a daft idea.
    HUH?
    Not at all.
    I'm not gonna lie, I was looking for an excuse to use that meme!
    I'm going to look into what other work Chris Forshage has done. It's an interesting design!
    edited January 2014
    HUH?
    Not at all.
    Ah ok.
    It is a very special guitar.
    I get how people think it is a bit ugly, but I love it to bits.
    I think from certain angles it is quite pretty:
    FWIW, I bought it after having several rounds of surgery, and for a long time it was the only guitar I could play for more than 10-15 minutes without pain.
  • @octatonic what are those two routes in the side? Is that weight relief or is it hiding something?
    edited January 2014
    They are basically the same as F holes- it is a hollow body guitar, really.
    They are on the top because you get less feedback with gain at stage volumes because the holes are 90 degrees to the speaker cone.
  • ICBMICBM Frets: 72807
    It goes back via the Klein guitar to the Ovation Breadwinner originally. They are odd-looking, but definitely comfortable - at least for classical position sitting down.
