Chainsaws - advice please
  • JeremiahJeremiah Frets: 631
    An axe is better for fighting zombies.
  • Emp_FabEmp_Fab Frets: 24435
    edited May 2017
    Flubumumumum...  flubumumumum...  flubumbrbrum... flubrmrmrmrmum....  flubbRAAAAAAAAAAAAAAAAAbudumdumdumdumdumdumdumdumdumdummmmdumdumdum....
    BrrrMM... BrrrMM...  BRAAAAAAAAAAAAAAAAAaaaaaAAAAAAAAAAAAaaaaaaAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAaaaaaaaaaaaaAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAaaaaaaaaaaAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
    ARGGHHHHHHHHHHHHH!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!  AAHHH!!!!!!!!!!!!!!!!!  GOD !!!!!!!!!!!!!!  AAAAAHHHHHHHHHHHH!!!!!!!!!!!!!!!
    Nee-naaw  Nee-naaw  Nee-naaw.....
  • rsvmarkrsvmark Frets: 1384
    Stihl user here. Reliable but a bastid to start. Get all the safety gear and go on a course.
    An official Foo liked guitarist since 2024
    Sambostar said:
    Oh and always wear face protection and a helmet and don't cut with your body over the line of the blade, when you experience a bit of kick back at full revs you'll know why, but I think they're generally safer than circular saws.
    This.
    I'm far more wary of my router and circular saw than a chainsaw.
  • SnapSnap Frets: 6265
    kinell, seems more trouble than its worth!! Maybe I'll make do with my bowsaw, and get a big chuffing axe instead.
    So, what about axes then!? Long handle, short......etc etc
    And really, your honour, its is for chopping wood, pruning trees.....and nothing else whatsoever!!
    Sambostar said:
    Rubbish
    just watching that is making my legs twitch.
  • BudgieBudgie Frets: 2108
    For splitting logs? A hammer and a wedge or log splitter with handle. For cutting logs a chainsaw imo. For branches a bow saw. G'wan g'wan yer know ye want to ;)
    I do want, I do!
    Got to be petrol too.
    I quite fancy a boiler suit and a Michael Myers mask too.....
    ... It's the only way to properly complete the ensemble!
  • JalapenoJalapeno Frets: 6398
    Stihl here too, but the hedge trimmer with the extension (will cut through stuff up to an inch thick).
    I'm with Sporkers when it comes to chainsaws - get somebody else in.
    I've a great pruning saw if something needs lopping.
    Feedback
    Its for cutting up dead trees, and making fire wood (logs) really. So, I suppose an axe may do it in combination with a bowsaw. Not as if I will be doing a lot of it, but enough I suppose.
  • octatonicoctatonic Frets: 33844
    I will use most tools but a chainsaw is one I leave to the experts.
  • 57Deluxe57Deluxe Frets: 7344
    Snap said:
    Sambostar said:
    Rubbish
    is not actually switched as no trimmings are evident and if it was switched on, then this would be nature's way of 'flushing the gene pool'....
    <Vintage BOSS Upgrades>
  • rainer2859rainer2859 Frets: 304
    Gransfors Bruks axe...proper job!
  • RockerRocker Frets: 4993
    Sporky said:
    My general opinion on chainsaws is that someone else should be operating them, and I should be many, many times the length of the blade away from them.
    I agree absolutely @Sporky.  And as well as being far away from said machine, I prefer not to watch the performance either.
    Nil Satis Nisi Optimum
    just been looking at these. V nice. Something earthy about them. I can see myself walking around hefting one of those, and generally doing nothing other than posturing and wafting it about. Perfect!
  • BigMonkaBigMonka Frets: 1783
    I've got a cheap chainsaw which has been fine for the last few years of felling trees and chopping logs. It's not as scary as you think, which then brings in the whole over-confidence being dangerous, so always treat it with respect.
    A petrol one is good for cutting things at the far end of the garden, but I find it too heavy to use for safely pruning whilst up a tree so prefer the bow saw for the extra control is gives.
    if just using it for chopping logs in the garage then an electric one is probably better as it's much easier to start and stop, and if you properly set up your cutting area then the chord won't be in danger. Electric one also stops you needing to store petrol, 2-stroke oil, and servicing of the engine.
    I used to have an electric one and it was shit compared to my petrol one.  The petrol one, even with a knackered chain, cuts about four times faster than the electric did when it was new.
    Plus, the sound of an electric chainsaw is rubbish compared to THIS !!!!
    Timbersports!!! That's great.
    Axes: http://www.fiskars.co.uk/new-axes
    X25 here. Some sort of funky ceramic metal head. Very light weight. Integral wedge in axe head to split rounds.
    Beware- these are devastatingly sharp. Mine went through my safety boot and into my foot. Just a glancing blow but still sliced through the boot and drew (a lot) of blood.
